Community
cancel
Showing results for
Search instead for
Did you mean:
TMcPi
Change Win 10 page file size with added 8 GB SD card ?
Is there any gain in changing the page file setting in Win 10 by using an added SD card, or by just changing the settings " initial and maximum " to the same size on C:\ ?
Miguel_C_Intel1
Hi TeeEm,
The page file needs to be in the same drive of the operating system so the sd card will not work. The page file is handled by the operating system and the amount of memory used is dynamic. I recommend you to keep this feature with the settings created by Windows® 10.
Mike C
TMcPi
Thanks Mike,
I thought as much just after I posted it.
Miguel_C_Intel1
Hi TeeEm,
You are welcome.
Mike C
