Intel® Makers
9877 Discussions
Choosing voltage level
PHult
New Contributor II
Is there any difference between supplying 3.3 or 4.5 V for power input?
I've heard some components run faster at higher voltages, does this logic apply to the Edison?
Community Manager
Hi Peter-H,
I understand what you are referring to, however, this is not the case for the Edison module. You can power it with an input voltage between the safe range (3.15V - 4.5V), and there is no difference if it's 3.3V or 4.5V, as long as it remains under the safe range the Edison will work in the same way.
Diego
Community Manager
Hi Peter-H,
Diego
