Intel® Makers
9868 Discussions
Code read out protection
bbogu1
I was wondering if there is any mechanism to protect MCU from code being read out after releasing it to public. It's a must have feature nowadays and without it the Intellectual Property on chip is endangered.
Is there any documentation on this topic yet? Does this feature is already included in the current D2000 chips and if yes, how do I enable it?
AdrianBurns
mariuszr
bartosz.firmwave
avijit.M
Alejandro_Q_Intel
The d2000 supports a lock-out feature where Flash writes/erases are disabled via a register write. All the info available is in the datasheet section 12.1.1. page 107. Along with this, is worth to mention that there is OTP (on time programmable memory), please refer to section 12.1.2
Alex
BZiol
Hi Intel,
Is it implemented in Quark something similar like CRP functionality in LPC uC
(https://www.lpcware.com/content/faq/what-are-code-read-protect-crp-levels-lpc17xx What are the Code Read Protect (CRP) levels on the LPC17xx? | www.LPCware.com )
(http://www.nxp.com/documents/application_note/AN10968.pdf http://www.nxp.com/documents/application_note/AN10968.pdf )
Bartosz
Sergio_A_Intel
We'll investigate if there's a way to protect the MCU code and reply back as soon as we have a suggestion.
-Sergio
Alejandro_Q_Intel
Alex
bbogu1
thanks for the info. Is there any code examples or more detailed documentation on this topic ?
The datasheet is still very light in details and would be very helpful to describe the proces of protecting the memory.
AdrianBurns
mariuszr
bartosz.firmwave
avijit.M
Sergio_A_Intel
All Quark D2000 documentation can be found here http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/documentation.html http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/documentation.html . The information that might be more relevant to your case, however, can be found in the reply posted by @aleesi. Regarding the examples, you can look for examples in the ISSM IDE.
-Sergio
