when I use the command "opkg update "
it gives me this message.
I found someone use edison in this communities have the same problem ,and not solved ,I am afrad of the same thing happen to me.
the message like this:
root@edison:~# opkg update
Downloading http://iotdk.intel.com/repos/2.0/intelgalactic/Packages http://iotdk.intel.com/repos/2.0/intelgalactic/Packages.
Updated list of available packages in /var/lib/opkg/iotkit.
Collected errors:
* parse_from_stream_nomalloc: Missing new line character at end of file!
root@edison:~#
and this happens in both edison-image-ww25.5-15 and edison-iotdk-image-280915
just after I flashed new firmware to edison and setup wifi.
I try to delete the files in /ete/opkg or just add a new line by enter an ENTER.
then the first time to input " opkg update" ,it is ok ,but second time it will give me the same error message.
well ,finally, I found if I use another access to internet ,it works well, so the problem comes from internet access.......
Thank you all for your help~~
in this error , the user have similar problem
Did you do any additional changes after flashing? In my case, I flashed to the latest image "edison-iotdk-image-280915". Then configured wifi with configure_edison –setup. Then put
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
in /etc/opkg/base-feeds.conf and ran opkg update.
I didn't receive any errors, are these the exact same steps you followed? Try to delete everything in /etc/opkg/base-feeds.conf and put the lines I mentioned above in base-feeds.conf.
Sergio
thank you for reply ,I followed your instruction and got the following message.
I think this strange problem may cause by some low level file or internet operation errors?
I don't know ,
I flashed it again, and after setting up the wifi ,I just type opkg update twice ,and got following message.
