Hello..
I am working on Intel Edison..I have interfaced edison with a sensor which is going to output digital values.And this data is to be sent to the localhost for analysis.I have made use of XAMPP for creating the localhost.I am a beginner here.Can anyone help me with the Client and the Server Code for the communication between My Intel Edison and the local host.?I prefer using Python.
Hello Atmeeya,
Thank you for your interest in the Intel® Edison.
In order to configure your Edison device as a Wi-Fi client, I'll suggest you to check section 4 of the Intel® Edison – Wi-Fi Guide ( https://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf).
Providing and debugging Python code is out of the scope of this technical support team, but perhaps you may be interested in checking this couple of alternatives:
Using Intel® Edison: Building an IoT Sensor Node
https://software.intel.com/en-us/blogs/2015/03/20/using-intel-edison-building-an-iot-sensor-node
Using Intel® Edison: Securely Connect IoT Sensor to the Internet with MQTT
https://software.intel.com/en-us/blogs/2015/04/06/using-edison-securely-connect-iot-sensor-to-the-in...
Intel® Edison Board: IoT Temperature Monitoring
http://www.instructables.com/id/Intel-Edison-Board-IoT-Temperature-Monitoring/
Just keep in mind that for the last example, the author uses Cloud Analytics from Intel, which has been discontinued. So please consider one of the alternatives suggested in this link https://software.intel.com/en-us/iot/hardware/edison# cloud.
If you have any other question, don't hesitate to contact us.
Have a nice day.
Andres V.
