Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Communication between arduino and Intel Edison
I want to use Intel edison as my main web server and arduino will send data to it
For example:
My arduino will receive information from ultra sonic sensor and then it send that to my Intel edison to update it on website
So can Arduino send data to Intel edison through serial communication ? And how to do it ?
Community Manager
Hi HeavenStone,
If I'm understanding you correctly you want to know if it is possible that your Edison reads the data from the Arduino Board using serial communication right? Yes it is possible, I personally recommend you to use the MRAA library to use this communication. You can look at the information of the https://github.com/intel-iot-devkit/mraa MRAA library repository to install it on the Edison (README).
In the repository you can also check the examples for the serial communication to get an idea how you can implement your own code.
I hope you find this information useful.
-Leonardo
Community Manager
Hi HeavenStone,
Did the information help you? Did you communicate the Edison with the Arduino?
Don't doubt to ask us if you have issues.
-Leonardo
