I'm running into a compile issue when I run a bitbake full-image -c populate_sdk command on a Joule work area (Log attached below for reference.).
This issue is impacting my productivity severely so any assistance you could offer would be gratefully received.
Log
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| -- The C compiler identification is unknown
| -- The CXX compiler identification is unknown
| -- The ASM compiler identification is unknown
| -- Found assembler: x86_64-refossdk-linux-gcc
| CMake Error at CMakeLists.txt:54 (project):
| The CMAKE_C_COMPILER:
| is not a full path and was not found in the PATH.
| Tell CMake where to find the compiler by setting either the environment
| variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
| the compiler, or to the compiler name if it is in the PATH.
| The CMAKE_CXX_COMPILER:
| x86_64-refossdk-linux-g++
| variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
| to the compiler, or to the compiler name if it is in the PATH.
| The CMAKE_ASM_COMPILER:
| variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
| -- Warning: Did not find file Compiler/-ASM
| -- Configuring incomplete, errors occurred!
| See also "/home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeOutput.log".
| See also "/home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeError.log".
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/temp/log.do_configure.26763)
Hi BigMo,
Thanks for interested in the Intel® Joule™ Platform.
We received your service ticket about this issue, since you have received a response there, we can continue the support there. For anyone interested in building the Joule image, please refer to this site: https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet… .
-Jose P.
