Community
cancel
Showing results for
Search instead for
Did you mean:
OMART4
Compile opencv 3.0 with yocto toolchain - Galileo
Jump to solution
Hi there,
I'm working on a java project that requires the Opencv libraries for the face recognition. I got no problems installing the Java Virtual Machine on the board and now I have to cross compile the Opencv 3.0 using the yocto toolchain. I'm new to yocto so could someone please help me doing this step?
Best regards
Tags (1)
Carlos_M_Intel
Hi boraz8,
Take a look at the http://downloadmirror.intel.com/23962/eng/Quark_BSP_BuildandSWUserGuide_329687_007.pdf BSP User Guide you will see in Section 7 how to build the cross compile toolchain for the board.
Also, for OpenCV3.0 I suggest you to build an image and import this recipe including all the dependencies required.
Charlie
Carlos_M_Intel
Hi boraz8,
Charlie
