Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Compiler and issues thereof
Jump to solution
As some of y'all may already know ..Some coding from the Arduino side don't work.... I was trying to figure out how to code an LCD 320x240... Wish we could just get away from using a very striped down compiler and use one like Coocox or just regular everyday Ansi C99 for 86x.. I have ran into the stuff that a regular compiler would know what to do with..Also alot of errors in the code is suppressed so watch what you code because some things won't work right... If any one wants the normal code for an lcd let me know ,but thus far I'm still working on it and have gotten rid of all the errors from the code that is in the library of the regular Arduino stuff (aka ITDB02) .. I've striped it down to plain ole C99 stuff...
Accepted Solutions
Highlighted
Re: Compiler and issues thereof
Jump to solution
Maybe you can give it a try to Mikal.Hart's LiquidCrystal library https://github.com/mikalhart/galileo-LiquidCrystal https://github.com/mikalhart/galileo-LiquidCrystal . If you try it and get a positive response let us know. Also I would like to mention the ITDB02 shield is not currently listed in the supported shields, you can check the list in this link: /docs/DOC-21855 https://communities.intel.com/docs/DOC-21855 . We will be testing more shields in the future, so I recommend you to check the list on a regular basis.
JPMontero_Intel
Highlighted
1 View
Jump to solution
JPMontero_Intel
