Community
cancel
Showing results for
Search instead for
Did you mean:
dnick1
Compiler error in arduino IDE, intel edison
Arduino: 1.6.5 (Windows 8.1), Board: "Intel® Edison"
Build options changed, rebuilding all
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++ -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\Blink.cpp -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\Blink.cpp.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++ -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\variant.cpp.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-gcc -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino\fast_... -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\fast_gpio_common.c.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-gcc -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino\fast_... -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\fast_gpio_nc.c.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-gcc -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino\fast_... -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\fast_gpio_pci.c.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-gcc -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux -c -g -Os -w -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -march=i686 -m32 -DARDUINO=10605 -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino -IC:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants\edison_fab... C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino\fast_... -o C:\Users\Danush\AppData\Local\Temp\build6157274215330665133.tmp\fast_gpio_sc.c.o
C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-gcc -m32 -march=i586 --sysroot=C:\Users\Danush\AppData\Roaming\Arduino15\packages\Intel\t...
Pedro_M_Intel
Hello danush,
Did you make sure that your Edison is plugged correctly? I mean, you might have moved the Edison's micro switch by mistake, a similar error is shown when you try to upload a sketch when the board is not plugged to the computer.
If you, in fact, are sure that the board is plugged correctly, I'd ask you to share with us a screenshot of your PC's device manager, specifically to the Ports (COM & LTP) section and a screenshot of the Arduino IDE, specifically to the Tools submenu.
Peter.
dnick1
Thanks for the help Peter. I don't know what the problem was but after i upgraded my Arduino IDE, things started to work out.
Having a good time with Edison now..
TMill16
I just wanted to say, I had exactly the same problem. And I fixed it by upgrading the Arduino IDE from 1.6.5 to 1.6.7
Community Manager
I can verify that after updating Arduino IDE from 1.6.5 to 1.6.8, the problem went away for me. So for future googlers: Try updating Arduino IDE to at least 1.6.7, or later!
