Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Compiling C using mraa on Edison
Jump to solution
The iotdk-ide-win SDK(Eclipse) works great on my Windows machine to compile, upload and run programs on my Edison. And of course, I can run the compiled executable directly on the Edison from its command line, too.
But I am not able to compile C programs using mraa references directly on the Edison. I get this error:
/tmp/ccqxH6Mw.o: In function `main':
analog_input.c:(.text+0x18): undefined reference to `mraa_aio_init'
analog_input.c:(.text+0x28): undefined reference to `mraa_aio_read'
collect2: error: ld returned 1 exit status
I would have expected the compiler to error on the # include "mraa.h" line if that was the problem.
I can compile other C programs on the Edison using gcc.
Any help?
Accepted Solutions
Highlighted
Re: Compiling C using mraa on Edison
Jump to solution
It is linker not compiler giving the error. Please make sure you add -lmraa to the options to let the linker know what library to link with.
Highlighted
Jump to solution
Highlighted
Jump to solution
Thanks Alexander. That was my problem. Here is an example for other rookies like me:
gcc -g analog_input.c -o analog_input -lmraa
