Intel® Makers
9880 Discussions
Compiling kernel modules
Community Manager
I need to modify the code of the kernel driver (hsu/mfd_core for work with RS485). I learned how to make changes to the kernel, but Bitbake reloads source codes and compiles whole kernel anew. After that I have to create an image and reflash it. It is too long. Is there a possibility of separating the module from the image and its compilation as .ko? Can I read anything about it?
Community Manager
Hello shmkv,
I will try to help you with this. To make a module of a driver you will have to make changes to the kernel while building it. You will have to modify the Linux kernel config file and on the specific driver you need, change its option to "m".
Could you please share with us the steps you have taken so far?
We will be waiting for your response.
-Peter.
Community Manager
Hello Peter,
I do a kernel cleanup:
bitbake -f -c clean virtual/kernel
after that I run compiling the kernel:
bitbake -f -c compile virtual/kernel
Before compiling the build script reloads the source code, and I am forced to replace the necessary files. I know what I'm doing wrong, but I don't know how to make a compile locally.
/.setup.sh --mode=devenv
command doesn't work (build environment 20160606)
Community Manager
I need to replace in file i386_edison_defconfig "y" to"m" for the desired option (CONFIG_SERIAL_MFD_HSU=m)?
And can I then compile this module separately? If so, how do I do that?
Community Manager
Hi shmkv,
Yes, in order to create a module of a kernel driver, you have to use the option 'm' on the kernel configuration. When you finish building the image I'd suggest you to search for the modules using the command find -name mfd_core*.
Also, the user @dbaba has a thread very similar to yours in which he compiles a kernel driver into a module. I suggest you to check it out, I believe it would be of much help for you. It can be found in https://communities.intel.com/message/422223# 422223 https://communities.intel.com/message/422223# 422223.
I hope this helps.
-Peter.
Community Manager
Hello shmkv,
Do you have any updates about this?
-Peter.
Community Manager
Hello Peter,
I changed the configuration of the kernel, but when building having problems with unresolved symbols. Now I'm trying to understand the reason. I'll post more information later. I also do not understand how to build kernel modules separately. I found a similar topic ( ), but I have the same problem with the version of the kernel.
Community Manager
Thanks for the update shmkv, please do keep us updated.
Have you checked the thread I posted above? It explains how to create a kernel module I thought it might be of help for you.
-Peter.
Community Manager
Hello Peter,
Yes, I have read the thread. I do about the same thing.
Yes, it explains how to create a module. I will have a lot of iterations correction code->compiling module->testing. I would like to find the most convenient and fastest way to do this.
I have still problems with kernel compilation. I am trying to understand what a hsu_register_board_info. See build console:
You can also run generated qemu images with a command like 'runqemu qemux86'
test@test-VirtualBox:~/iot-devkit-yp-poky-edison-20160606/build_edison$ bitbake virtual/kernel -c configure -f -v
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |# | ETA: 00:00:00
Loaded 2238 entries from dependency cache.
WARNING: No recipes available for:
/home/test/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-iot-devkit/recipes-kernel/linux/linux-yocto-quark_3.8.bbappend
NOTE: selecting linux-externalsrc to satisfy virtual/kernel due to PREFERRED_PROVIDERS
NOTE: Resolving any missing task queue dependencies
NOTE: selecting pseudo-native to satisfy virtual/fakeroot-native due to PREFERRED_PROVIDERS
NOTE: selecting binutils-cross-i586 to satisfy virtual/i586-poky-linux-binutils due to PREFERRED_PROVIDERS
NOTE: selecting gcc-cross-i586 to satisfy virtual/i586-poky-linux-gcc due to PREFERRED_PROVIDERS
NOTE: selecting gcc-runtime to satisfy virtual/i586-poky-linux-compilerlibs due to PREFERRED_PROVIDERS
NOTE: selecting glibc to satisfy virtual/libc due to PREFERRED_PROVIDERS
NOTE: selecting linux-externalsrc to satisfy runtime kernel-base due to PREFERRED_PROVIDER_virtual/kernel = linux-externalsrc
NOTE: selecting linux-externalsrc to satisfy runtime kernel-image due to PREFERRED_PROVIDER_virtual/kernel = linux-externalsrc
NOTE: selecting glibc to satisfy runtime libsegfault due to PREFERRED_PROVIDER_virtual/libc = glibc
NOTE: selecting glibc to satisfy runtime glibc-dev due to PREFERRED_PROVIDER_virtual/libc = glibc
NOTE: selecting glibc to satisfy runtime glibc due to PREFERRED_PROVIDER_virtual/libc = glibc
NOTE: selecting glibc to satisfy virtual/i586-poky-linux-libc-for-gcc due to PREFERRED_PROVIDERS
NOTE: selecting linux-libc-headers to satisfy linux-libc-headers due to PREFERRED_PROVIDERS
NOTE: selecting gcc-cross-i586 to satisfy virtual/i586-poky-linux-g++ due to PREFERRED_PROVIDERS
NOTE: selecting libgcc to satisfy libgcc due to PREFERRED_PROVIDERS
NOTE: selecting gcc-cross-initial-i586 to satisfy virtual/i586-poky-linux-gcc-initial due to PREFERRED_PROVIDERS
NOTE: selecting glibc-initial to satisfy virtual/i586-poky-linux-libc-initial due to PREFERRED_PROVIDERS
NOTE: selecting linux-libc-headers to satisfy runtime linux-libc-headers-dev due to PREFERRED_PROVIDER_linux-libc-headers = linux-libc-headers
NOTE: selecting libgcc to satisfy runtime libgcc due to PREFERRED_PROVIDER_libgcc = libgcc
Build Configuration:
BB_VERSION = "1.24.0"
BUILD_SYS = "i686-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "i586-poky-linux"
MACHINE = "edison"
DISTRO = "poky-edison"
DISTRO_VERSION = "1.7.3"
TUNE_FEATURES = "m32 core2"
TARGET_FPU = ""
meta
meta-intel-arduino
meta-intel-edison-bsp
meta-intel-edison-distro
meta-intel-iot-middleware
meta-java
meta-oic
meta-filesystems
meta-networking
meta-oe
meta-python
meta-ruby
meta-webserver
meta-yocto
meta-yocto-bsp = ":"
NOTE: Preparing runqueue
NOTE: Marking Active Tasks
NOTE: Pruned 1262 inactive tasks, 253 left
NOTE: Assign Weightings
NOTE: Compute totals (have 1 endpoint(s))
NOTE: Invalidate task do_configure, /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-externalsrc.bb
NOTE: Tainting hash to force rebuild of task /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-externalsrc.bb, do_configure
WARNING: /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-externalsrc.bb.do_configure is tainted from a forced run
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
cd /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0
+ do_configure
+ cp /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/linux-kernel/arch/x86/configs/i386_edison_defconfig /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_SERIAL is not set.*/CONFIG_USB_SERIAL=y/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_SERIAL_FTDI_SIO.*/CONFIG_USB_SERIAL_FTDI_SIO=m/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_USBNET.*/CONFIG_USB_USBNET=y/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_RTL8150.*/CONFIG_USB_RTL8150=m/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_RTL8152.*/CONFIG_USB_RTL8152=m/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_GSPCA_OV534 is not set.*/CONFIG_USB_GSPCA_OV534=m/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ sed -i s/.*CONFIG_USB_GSPCA_OV534_9 is not set.*/CONFIG_USB_GSPCA_OV534_9=m/ /home/test/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
+ ret=0
+ trap 0
+ exit 0
NOTE: Checking autotools environment for common misconfiguration
NOTE: linux-externalsrc: md5 checksum matched for file://COPYING;md5=d7810fab7487fb0aad327b76f1be7cd7
NOTE: Tasks Summary: Attempted 253 tasks of which ...
Community Manager
The first thing that caught my eye was the following line:
"WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution."
This tells me that you are using Ubuntu 16 and as it is stated in that line you might experience unexpected issues. So, if possible, I would suggest you to install an Ubuntu distribution that is compatible with the BSP. You can check the supported Linux distributions in section 1.3.1 of Yocto's Mega Manual ( http://www.yoctoproject.org/docs/1.7.3/mega-manual/mega-manual.html).
Have you been able to build the standard image? Or do you also have this issue when trying to build it?
Let me know.
-Peter.
Community Manager
Hi Peter
Yes, standard image is well being built. Moreover, I added the modules in the kernel without any problems, but problems arise when using CONFIG_SERIAL_MFD_HSU=m.
I will try to use ubuntu 14. I didn't think that it can significantly affect the build process.
Community Manager
I understand. Please do try with Ubuntu 14 and let us know how it goes.
We'll be waiting for your response.
-Peter.
Community Manager
Hello shmkv,
-Peter.
