Intel® Makers
9872 Discussions
Compiling .net application on mono
SR11
how to compile .net application project on yocto? xbuild is not getting installed along with mono on yocto.
Pedro_M_Intel
Hello Blackhole,
Both mono and xbuild can be found on http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html AlexT's Repo. If you don't have it set up, follow the steps in the link above. If you have already set it up follow these steps:
opkg update
opkg install mono
opkg install mono-xbuild
Peter.
Pedro_M_Intel
Hello Blackhole,
opkg update
opkg install mono
Peter.
SR11
Hi, Peter,
It was helpful.
But compilation has to be done with following command:
>>mono path to xbuild.exe path to .sln
Srikanth
Pedro_M_Intel
xbuild.exe can be found in the following directories:
/usr/lib/mono/4.5/xbuild.exe
/usr/lib/mono/xbuild/12.0/bin/xbuild.exe
/usr/lib/mono/xbuild/14.0/bin/xbuild.exe
I found them using the find command: find / -name xbuild.exe.
Peter.
