Community
cancel
Showing results for
Search instead for
Did you mean:
kfchoong
New Contributor II
Compute Stick (Linux) hangs after reboot
Occasionally, my Compute Stick (Linux version) will hang after I perform a reboot. It will basically hang at the boot-up splash screen and I will have to manually power it off by holding to the "power button". This behaviour doesn't happen all the time, maybe 1 out of 10 to 20 times? As I need to perform an automatic reboot daily, and the system is unattended, it is causing some problem for me. Any idea what is the issue?
Amy_C_Intel
Hello, Choong:.
Could you please let us know Intel® Compute Stick model?
Amy.
kfchoong
New Contributor II
Hi Amy,
I am using the Windows version (STCK1A32WFC), running the image from the Linux version. I know that for my case, Intel will not be obligated to support it, but I do find it interesting that the problem doesn't happen all the time. It is hard for me to narrow down if it is a hardware compatibility issue or a software problem.
Choong
Amy_C_Intel
In this case like you mentioned this configuration is not supported by Intel but I understand and let's hope that other users can join this thread and add more information in regard to this behavior.
kfchoong
New Contributor II
Hi Amy,
Thanks. Yes, I do hope that someone from this forum will be able to shed some light to my problem.
Cesar_B_Intel
Hello Choong,
Please check on the following post: /thread/76216 Ubuntu LiveCD for the STCK1A32WFC (Windows).
Confirm if you applied any patches to prevent eMMC RPMB timeouts? REF - https://dev-nell.com/rpmb-emmc-errors-under-linux.html https://dev-nell.com/rpmb-emmc-errors-under-linux.html
You could try linuxiumUbuntu LiveCD for the STCK1A32WFC (Windows) https://drive.google.com/open?id=0B99O3A0dDe67Q0dzalFHWWhMNmc ubuntu-14.10-desktop-linuxium-ics.iso - Google Drive *
You could get important information here http://kernel.ubuntu.com/git/ubuntu/unstable.git/commit/?id=4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4 http://kernel.ubuntu.com/git/ubuntu/unstable.git/commit/?id=4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4*
Take into consideration the fact Intel is not responsible for any content outside Intel's website and here is the official information about validated Operating Systems for Intel Compute Stick: http://www.intel.com/support/motherboards/desktop/sb/CS-035602.htm Intel® Compute Stick — Supported Operating Systems
Caesar B_Intel.
*Other names and brands may be claimed as the property of others.
kfchoong
New Contributor II
Hi Caesar,
Thanks for all the links. Will definitely check them out.
FYI, I am using the image from the Ubuntu version of ICS. Do you know if that version actually has the eMMC RPMB patched?
Choong
kfchoong
New Contributor II
Hi Caesar,
Went through the links, I don't think the problem is because of the eMMC RPMB issue. My problem doesn't happen all the time, in fact, it is pretty rare. I also tried to search for the error in the log files, but couldn't find any. Any idea what else could be the problem?
Choong
Cesar_B_Intel
Hello Choong,
Thanks for your quick response.
Could you please upload the log files?
Please let me know which image did you use for the Intel® Compute Stick?
Caesar B_Intel.
