Intel® Makers
9872 Discussions
Compute Stick and realsense r200 camera ?
Community Manager
does any one know if the BOXSTK1AW32SC can work with an intel realsense r200 camera ? and if so what are the limitations of such configuration?
Community Manager
Hello pana,
Thank you for joining the Intel® Compute Stick community.
The minimum requirements for the Intel® RealSense™ R200 Camera can be found here; http://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-techn... http://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-techn...… . See below for the details;
It seems like the Intel® Compute Stick is compatible with the camera; however, after comparing these two the only limitation here could be hardware related. In this case, the memory required is 2 GB which can vary depending on the application you will be using. You might need more than two 2 GB, and the Intel® Compute Stick only supports 2 GB.
Hope it helps, and if you have more questions please let me know.
Amy.
Community Manager
pana, hope the information posted above helped you.
Amy.
