Intel® Makers
9882 Discussions
Compute Stick seems to sleep for no reason
AAshl2
Hi
I have a fully working Intel Compute Stick (stck1a32wfc) Windows 10 home (latest), all power saver is off (no sleep for anything), no keyboard installed (its a media box for the TV), i think its BIOS set to green or balanced mode (not Windows, but the BIOS).
It will "sleep" with the blue light on for what appears to be no reason, when i turn the TV to it, nothing, no PING (we use a StarTech USB Ethernet adapter, not WiFi), i have to hold the power button to turn it off then do it again to turn it on.
Windows complains about last know boot cycle for no reason, however it will have nothing in the event log for 10 days (so its sleeping), so whats going on? How do i stop this from sleep, is this a keyboard / mouse issue (as it doesn't have one and if it did it would be bluetooth anyway), however it appears dead and no setting should allow this to sleep at all from Windows.
Ideas?.
Many Thanks
IUman
Hello mailto:contact@ashleygriffin.ca contact@ashleygriffin.ca,
Thank you for joining the Intel communities.
Please try installing the latest graphics driver, you can download it here:
https://downloadcenter.intel.com/download/25647/Graphics-Intel-HD-Graphics-driver-for-Intel-Compute-... Download Graphics: Intel® HD Graphics driver for Intel® Compute Stick
Probably you have done this already but you can try the following:
  1. Access control panel
  2. Click system and security
  3. Power options
  4. Click change plan setting
  5. Turn off display to never
  6. Put the computer to sleep to never
  7. Click change advance and power settings
  8. Click change settings that are currently unavailable
  9. You will see the sleep option, click on it and set hibernate after never
  10. Under display you can set it to never.
Please let me know if this can help you.
Ivan
AAshl2
Hi
Well this is interesting, we have the Intel Driver Update Utility on this Stick, it says the Intel Graphics driver is the latest (v15.33.39.4276), however looking at your link and the drivers for this hardware thers is a later driver.
I have installed this, so whats the point of an Intel Driver Update utility when it seems to report the wrong latest driver?
Also was the Graphics card driver causing this sleep for no reason and couldn't wake up issue?
My power plan was also set to never sleep, never turn anything off already.
IUman
We have set up this unit and we have not experience this problem, the unit did it works fine.
Do you have the latest BIOS version? If not, try updating the BIOS , you can download the latest version at the following link:
https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]
BIOS Update Instructions:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000006039.html F7 BIOS Update Instructions for Intel® Compute Stickhttp://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000006039.html
Ivan
