Intel® Makers
9881 Discussions
Compute Stick working with 4G USB Modem
Community Manager
Hi!
Can I use a USB 4G Modem like Huawei's on Intel Compute Stick? Does the port have the power to feed the modem? It would be work smoothly?
Thank you guys!
Jean
n_scott_pearson
Super User Retired Employee
It should work. I might recommend that you use a USB extension cable (or hub) to move the modem physically some distance from the ICS unit itself, so that no interference with (or from) the internal WiFi circuitry occurs...
Hope this helps,
n_scott_pearson
Hope this helps,
Community Manager
Hi all,
Thanks Scott for the suggestion, Please Jeankuss let us know if it helps you.
Hellen.
