i have a scenario in my mind to configure my Edison via bluetooth like Wifi , Device name , etc...
i have search if someone did that but unfortunately i could not find. i was thinking if that possible to do it through https://software.intel.com/en-us/articles/connecting-the-intel-edison-board-to-your-android-phone-wi... SPP
I appreciate if you have any idea or suggestion.
Thank you
Hello KhaledSMQ,
I believe achieving this might be quite challenging, I mean, I have never tried to send Linux commands over Bluetooth and actually I think that would not be the correct approach for this. I believe the best option would be to do something like AP mode setup (https://software.intel.com/en-us/getting-started-with-ap-mode-for-intel-edison-board IoT - Getting started with Access Point (AP) Mode for the Intel® Edison board | Intel® Developer Zone) but instead of using AP mode you would have to create a PAN and connect to your Edison through. I believe if you are able to achieve this you might be able to set a setup site in Edison's PAN IP. If you are interested in this approach I suggest you to read edison-config-server.js that can be found in /usr/lib/edison_config_tools/. That's the file that configures the setup webpage, for this approach it would be great to understand how it works.
Peter.
Hello KhaledSMQ,
Peter.
