Community
cancel
Showing results for
Search instead for
Did you mean:
akuma85
Configuring Static IP for Edition Access Point
I am trying to configure static IP for edition Access point. But I am not able to figure out how to do it. I found /etc/network/interfaces file is not there in edition. People suggested to try connmanctl. I tried "connmanctl config --ipv4 ipaddr mask gateway" But it returned Error 'config': Invalid argument. Kindly suggest some way to do this.
Tags (1)
Community Manager
Hello arunkumark,
Thank you for your interest in the Intel® Edison Breakout Board.
My recommendation for you is to check the following document, especially sections 4.2 and 7.2:
Intel® Edison – Wi-Fio http://download.intel.com/support/edison/sb/edison_wifi_331438001.pdf
Also there is a community thread where community member maathor receives assistance to change his IP address: https://communities.intel.com/message/465664# 465664 https://communities.intel.com/message/465664# 465664.
Additionally, I found a guide that shows certain steps that you may find useful, it presents the process from the connection to the network to the corresponding setting of the static IP address:
Connecting to the network
We are going to use connman to configure the Wi-Fi connection. Run the following commands to start the connman service and to enable it:
systemctl start connman systemctl enable connman connmanctl
We have entered in the connman interactive mode. Run the following commands to enable Wi-Fi and to scan the available networks:
enable wifi scan wifi
When the message Scan completed for wifi appears, run the following command to display the networks scanned:
services
The networks available will be displayed in the following format: . The service name is a long string that you will need to connect to the desired network. Select and connect to the desired network by running the following commands:
agent on connect
Then enter the network password when the command prompt asks for it. At this point you should be connected to the network selected. Exit the connman interactive mode by running the following command:
exit
Gathering network information
We are going to need the gateway, netmask and broadcast information to set the static IP address. With the following commands we will get the necessary information:
For gateway information: netstat –nr
For netmask and broadcast information: ifconfig wlan0
Setting the static IP address
With the netmask and gateway information, run the following command to set the static IP address:
connmanctl config --ipv4 manual
Now the Edison should have the static IP address set.
Maintaining the static IP address after reboot
At this point the static IP address is set, but it will be erased after reboot. In order to maintain it after reboot, the interfaces file must be created and configured. To create the interfaces file, the directory /etc/network must be created first. The following command creates this directory:
mkdir /etc/network
Then, create and edit the /etc/network/interfaces file by running the following commands:
echo auto wlan0 >> /etc/network/interfaces echo iface wlan0 inet static >> /etc/network/interfaces echo address >> /etc/network/interfaces echo netmask >> /etc/network/interfaces echo broadcast >> /etc/network/interfaces echo gateway >> /etc/network/interfaces echo dns-nameservers 192.0.2.2 >> /etc/network/interfaces echo wpa-ssid >> /etc/network/interfaces echo wpa-psk >> /etc/network/interfaces
If the process is done properly, Edison should maintain the static IP address set even after reboot.
Please let me know if you find this information useful.
If you have any update or question, don't hesitate to contact us.
Have a nice day.
Andres V.
Community Manager
Hello arunkumark,
I was wondering if you could check the information provided.
Andres V.
