So I am currently working on a project where I need the Edison to trigger a USB camera and send images to a ground station over a Ubiquit bullet data link. The camera triggering works perfectly ( I am utilizing a USB power splitter since the Edison can't power the camera). However, I also need it to simultaneously connect to the Bullet M5 as a USB station. The bullet is currently being powered by a separate source over POE (power over ethernet), and I attempted to use the J3Create USB3.0 to ethernet adapter (OTG) ( I assume it's ok since USB3.0 is backwards compatible to USB2.0) [http://www.j5create.com/our-products/ethernet-adapters/jue130.html http://www.j5create.com/our-products/ethernet-adapters/jue130.html] . However, the jcreate adaptor never lights up, so I attempted to use the same USB splitter method as the camera since maybe the edison can't power the adapter? and still there was no data being transmitted or power. I tried connecting the adapter both to the USB A port and micro-usb port, with no luck. However, I most likely need to connect it to the micro-usb port in host mode since the usb -A port is being utilized by the camera. Is there a way to connect the Bullet M5 station the edison? In addition, if it is,is possible to also connect the USB camera I am using too? (one through the USB-A port and one through a micro port)?
Ubiquiti bullet m5 [https://www.ubnt.com/airmax/bulletm/ Ubiquiti Networks - Bullet™M ]
Hi Dylan,
Thanks for your interest in the Intel® Edison Platform.
When the Intel Edison is selected in USB host mode, it always requires use of an external power adapter, we would like to request you a picture of the configuration you have made, this is in order to give you a better assistance.
We'll be waiting for your reply.
-Yermi
Hi Dylan,
We would like to know if you still need assistance with this case, if this is the case, could you please share the configuration you are using?
-Yermi
