Intel® Makers
9881 Discussions
Connect intel galieo gen 2 with c# ,Cable COM to usb
TThan3
I connect C# with intel galieo gen 2 ,Cable COM to usb.
Because i can't buy cable Rs232 to DB9
https://www.amazon.com/C2G-Cables-Go-02444-Velocity/dp/B006QSQVBM/ref=pd_sim_147_1?ie=UTF8&dpID=31qj... https://www.amazon.com/C2G-Cables-Go-02444-Velocity/dp/B006QSQVBM/ref=pd_sim_147_1ie=UTF8&dpID=31qjy...
I have cable COM to usb
http://www.vatgia.com/tanthanhanpc&module=product&view=detail&record_id=1252811 Cable USB to COM RS232 (HL-340) | Trung Tâm TM & DV Tin Học Tân Thành An http://www.vatgia.com/tanthanhanpc&module=product&view=detail&record_id=1252811 http://www.vatgia.com/tanthanhanpc&module=product&view=detail&record_id=1252811
I want connect with head COM plugged into the computer, and USB plugged into the board intel galieo gen 2.
Do I need to install additional software what the board intel galieo gen 2 or computer?
FTinetti
Honored Contributor I
Hi ToMBe0,
I think the cable of the second image will not be useful in Intel Galileo Gen 2.
There are several threads about RS232 communication/s in Galileo Gen 2:
BR,
Fernando.
Community Manager
Hello ToMBe0,
As Fernando mentioned the 3.5mm cable won't help you when using a Gen 2. I'd suggest you to check the following document in order to learn which cable you should use with each Galileo: http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006343.html
Also, you mention that you would like to use C# , may I ask which image you are using? If you would like to use C# you will have to install mono's packages from source, you'll find more information in http://www.mono-project.com/docs/about-mono/supported-platforms/linux/.
I hope this helps.
Peter.
Community Manager
Hello ToMBe0,
Do you have any update about this? Do you still need help?
-Peter.
