Intel® Makers
9868 Discussions
Connect to WLAN under C++
CChri35
New Contributor II
Hi!
I'm using this code to connect to a target WLAN under C++:
string ssid = "myssid";
string password = "mypassword";
system("systemctl start wpa_supplicant");
system("wpa_cli -i wlan0 disconnect");
system("wpa_cli -i wlan0 remove_network all");
system("wpa_cli -i wlan0 add_network");
system("wpa_cli -i wlan0 set_network 0 mode 0");
system("wpa_cli -i wlan0 set_network 0 ssid \\\"" + ssid + "\\\"");
system("wpa_cli -i wlan0 set_network 0 auth_alg OPEN");
system("wpa_cli -i wlan0 set_network 0 key_mgmt WPA-PSK");
system("wpa_cli -i wlan0 set_network 0 proto RSN");
system("wpa_cli -i wlan0 set_network 0 psk \\\"" + password + "\\\"");
system("wpa_cli -i wlan0 set_network 0 scan_ssid 1");
system("wpa_cli -i wlan0 select_network 0");
system("wpa_cli -i wlan0 enable_network 0");
system("wpa_cli -i wlan0 reassociate");
Sometimes it connects well, but sometime, it doest.
"wpa_cli -i wlan0 status"
then shows:
.wpa_state=SCANNING
p2p_device_address=7a:4b:87:aa:6f:a0
address=78:4b:87:aa:6f:a0
.bssid=b8:55:10:d5:14:ac
ssid=myssid
id=0
mode=station
pairwise_cipher=CCMP
group_cipher=CCMP
key_mgmt=WPA2-PSK
wpa_state=4WAY_HANDSHAKE
.wpa_state=SCANNING
.wpa_state=SCANNING
.wpa_state=SCANNING
.wpa_state=DISCONNECTED
CFERR17
I have the same behaviour, with a bash script :
# !/bin/sh
if [ $# -ne 2 ]
then
echo "usage: $0 SSID passphrase"
exit
fi
config="/tmp/${1}.conf"
cat <<EOF > "$config"
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
config_methods=virtual_push_button virtual_display push_button keypad
update_config=1
fast_reauth=1
device_name=Edison
manufacturer=Intel
model_name=Edison
EOF
wpa_cli -i wlan0 terminate 2> /dev/null
systemctl stop wpa_supplicant
wpa_supplicant -B -i wlan0 -c "$config"
udhcpc -i wlan0 -n
I need to reboot my wifi when it fails.
Hope this help to understand!
CChri35
New Contributor II
That's funny. Because when I run my bash script manually (which does the same as the code) it works..
How can that be?
if [ $# != 2 ] ; then
echo "$0 "
exit
fi
wpa_cli -iwlan0 disconnect
wpa_cli -iwlan0 remove_network all
wpa_cli -iwlan0 add_network
wpa_cli -iwlan0 set_network 0 mode 0
wpa_cli -iwlan0 set_network 0 ssid \"$1\"
wpa_cli -iwlan0 set_network 0 auth_alg OPEN
wpa_cli -iwlan0 set_network 0 key_mgmt WPA-PSK
wpa_cli -iwlan0 set_network 0 proto RSN
wpa_cli -iwlan0 set_network 0 psk \"$2\"
wpa_cli -iwlan0 set_network 0 scan_ssid 1
wpa_cli -iwlan0 select_network 0
wpa_cli -iwlan0 enable_network 0
wpa_cli -iwlan0 reassociate
wpa_cli -iwlan0 status
Community Manager
What image are you using? What happens if you use wpa_cli -iwlan0 set_network 0 scan_ssid 0?
Sergio
CChri35
New Contributor II
Im Using 3.10.17-poky-edison+.
gives me "OK"
CChri35
New Contributor II
I now saw that the log of the wpa_supplicant throw this:
Jun 10 14:54:15 edison wpa_supplicant[768]: wlan0: Trying to associate with b8:55:10:d5:14:ac (SSID='mySSID' freq=2462 MHz)
Jun 10 14:54:15 edison wpa_supplicant[768]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=1
Jun 10 14:54:15 edison wpa_supplicant[768]: Retrying assoc: 1
Jun 10 14:54:15 edison wpa_supplicant[768]: wlan0: CTRL-EVENT-DISCONNECTED bssid=b8:55:10:d5:14:ac reason=3 locally_generated=1
Jun 10 14:54:15 edison wpa_supplicant[768]: current_ssid == NULL
Jun 10 14:54:15 edison wpa_supplicant[768]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=b8:55:10:d5:14:ac status_code=1
Jun 10 14:54:15 edison wpa_supplicant[768]: Retrying assoc: 2
When you do a google search in "reason=3" in combination with wpa_supplicant, you get some threads who don't say what's the reason
for failing, but say that sometimes it it helpful to kill the service and try again.
In te end not very satifying because there is no answer for the reason.
Please tell me if you know more about reason=3.
Community Manager
Do you still need assistance with this case? I noticed in previous posts that you're not using the latest image. You can download the latest image here https://software.intel.com/edison-image/latest https://software.intel.com/edison-image/latest . After flashing this image, try again to run wpa_cli -iwlan0 set_network 0 scan_ssid 0 and let us know your results.
-Sergio
