Community
cancel
Showing results for
Search instead for
Did you mean:
Yaniv_S_Intel
Connect to wireless network via Ubuntu terminal on Joule board
I'm trying to connect to my enterprise network at work with my Intel Joule board.
I need to do that by using Ubuntu 16.04 terminal commands.
The wireless network is a WPA/WPA2 security type.
The interface name is 'wlp1s0' (not 'wlan0')
I read some guidelines about running commands from terminal and I followed steps from (https://askubuntu.com/questions/138472/how-do-i-connect-to-a-wpa-wifi-network-using-the-command-line wireless - How do I connect to a WPA wifi network using the command line? - Ask Ubuntu):
Here are the steps I took:
1) run sudo apt-get install wpasupplicant
2) I put my SSID (the network name/title as shown in wireless network list in upper right icon tray) and my password into /etc/wpa_supplicant.conf like so:
network={
ssid="ssid_name"
psk="password"
3) Run the following commands:
sudo wpa_supplicant -B -iwlp1s0 -c/etc/wpa_supplicant.conf -Dwext
sudo dhclient wlp1s0
** Nothing happens, the terminal is stuck and I exit with "Ctrl+Z"
Can anyone help me understand how to connect my Joule to the wifi via terminal commands?
Thanks in advance,
Yaniv
Jitendra_S_Intel
Some things I did that might help. Steps below are mixed (network manager and mods to interfaces file):
1. I used the GUI to connect to the Joule to AP. This created a /etc/NetworkManager/system-connections/ file. This file contains details to connect the AP, including the passphrase. This step may not be needed but I didn't experiment.
2. I also used wpa_supplicant to create /etc/wpa_supplicant file
3. Modified /etc/network/interfaces file. Mine is pasted below.
test@joule:/etc/network$ cat interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto wlp1s0
wpa-conf /etc/wpa_supplicant.conf
Yaniv_S_Intel
I didn't quite understood what to write where and what command to execute after?
Here is my interfaces file:
# /etc/Network/interfaces #
auto lo
iface wlp1s0-<<em>SSID NAME> inet dhcp
wpa-psk <<em>PSK>
wpa-ssid <<em>SSID>
wireless-channel auto
1) Where to write "auto wlp1s0"? running it in terminal, "auto" command is not recognize
2) Where to write "wpa-conf /etc/wpa_supplicant,conf"? after the auto command?
3) After the configuration are all done, what command did you run in terminal?
Jitendra_S_Intel
My file looks like this:
auto lo
auto wlp1s0
The /etc/wpa_supplicant.conf file is created by using wpa_passphrase tool
After above changes, reboot.
