Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Connecting Edison to a captive WiFi portal?
I would like to connect my Edison to the WiFi in my co-working space. This requires connecting to WiFi, and then logging in on a web page that your web browser is redirected to. (I believe this is commonly referred to as a "captive WiFi portal". Does anyone know how to do this with an Edison?
Highlighted
Haven't tried myself yet but you might try on a terminal using a console browser like "w3m". For Javascript parts you might requrire "w3m-js" Or you try something like http://phantomjs.org/ PhantomJS | PhantomJS
Highlighted
With http://links.twibright.com/ links I was able to login and is already installed in the last image. (iot-devkit-prof-dev-image-edison-20160315)
