Intel® Makers
9868 Discussions
Connecting to two Realsense T265 cameras using Python.
BMull7
Hi!
I am trying to connect to two T265 cameras. I used this example https://github.com/IntelRealSense/librealsense/issues/1735 and changed the config_x.enable_stream(...) lines to config_x.enable_stream(rs.stream.pose).
But then at line pipeline_1.start(config_1) it comes up with the fault RuntimeError: No device connected although both cameras are plugged in.
With one camera I run this code and it works:
  pipe = rs.pipeline()
  # Configure the pipeline
  cfg = rs.config()
  cfg.enable_stream(rs.stream.pose) # Positional data (translation, rotation, velocity etc)
  # Start the configured pipeline
  pipe.start(cfg)
Thanks for your help :)
BMull7
Ok, turns out if I address the cameras with their serial numbers and start the pipeline before I do the same with the second camera it works!
pipeline_1 = rs.pipeline()
config_1 = rs.config()
config_1.enable_device('+25122110510')
config_1.enable_stream(rs.stream.pose)
...from Camera 2
pipeline_2 = rs.pipeline()
config_2 = rs.config()
config_2.enable_device('929122110956')
config_2.enable_stream(rs.stream.pose)
pipeline_2.start(config_2)
BUT I would like to be able to ask the serial numbers of the cameras first so I can check with the program if both are there or not and to not have to hard-code the serial numbers. Unfortunately though, when I work with the context managers to get the connected devices and their serial numbers it will come up with the fault above again...
Any ideas?
Thanks!
RandallMan_B_Intel
Hello BMull7,
Thank you for reaching out. To receive support for Intel RealSense cameras, please post your questions on https://support.intelrealsense.com/hc/en-us or open a ticket at https://support.intelrealsense.com/hc/en-us/requests/new
Randall B.
Intel Customer Support Technician
A Contingent Worker at Intel
