Intel® Makers
9882 Discussions
Connman and Ubilinux connection problems
IVan
After installing connman (apt-get install connman) I am unable to connect to wifi. After this I was unable to connect to wifi, so I began following the instructions found here http://www.malinov.com/Home/sergey-s-blog/intelgalileo-addingwifi Intel Galileo Meets Wireless - Malinov Family Web Presence to connect to wifi.
I am unable to use connmanctl. The command is not found. Is there anything else I must install? I assumed that there was, knowing I would need an internet connection to do this I did some troubleshooting/ attempted using wpa_supplicant to connect to the internet. Multiple times I ran into problems related to rfkill.
The output of "rfkill list all":
0: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: brcmfmac-wifi: Wireless LAN
Soft blocked: yes
Hard blocked: no
2: bcm43xx Bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
Running "rfkill unblock all" changes nothing
Finally, the output of ifconfig. I assume the absence of wlan0 is related to the soft block on the wireless connection.
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:592 errors:0 dropped:0 overruns:0 frame:0
TX packets:592 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:40760 (39.8 KiB) TX bytes:40760 (39.8 KiB)
I am not entirely sure if or how this information is related, but I do not know where to go from here. Any advice is appreciated.
Pedro_M_Intel
Hello ChompChomp,
I'm not sure if https://software.intel.com/en-us/blogs/2014/04/25/wireless-galileo-on-yocto-linux-iot-devkit-image WiFi access on Intel® Galileo with Yocto* Linux works on Ubilinux, but it does in the eglibc version of Yocto. I'd suggest you to give it a shot and if you still have issues after this I'd suggest you to post your question in http://www.emutexlabs.com/forum/ubilinux EmutexLabs.
Peter.
Pedro_M_Intel
Hello ChompChomp,
Peter.
