Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Controlling stepper motors using intel galileo
Hi Guys
i am struggling to run my stepper motors on the intel galileo as they work perfect on the arduino uno , so i am thinking maybe I am missing something fundamental and below is a simple code I use to test the bipolar stepper motor connected to a sparkfun easy driver then into the intel galileo board.
int Distance = 0; // Record the number of steps we've taken
void setup() {
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
void loop() {
digitalWrite(9, HIGH);
delayMicroseconds(100);
Distance = Distance + 1; // record this step
// Check to see if we are at the end of our move
if (Distance == 3600)
// We are! Reverse direction (invert DIR signal)
if (digitalRead(8) == LOW)
digitalWrite(8, HIGH);
else
// Reset our distance back to zero since we're
// starting a new move
Distance = 0;
// Now pause for half a second
delay(500);
Please advise on how to make it work on the intel galileo
Tags (1)
Highlighted
Re: Controlling stepper motors using intel galileo
Hi Mashilekhutso27
I don't have a stepper to test it, but by reviewed this other post /thread/49111 https://communities.intel.com/thread/49111 that is also from stepper motors, and looking at the answer marked as correct, I would say that maybe you can try using pin 2 and 3 with a fast output configuration take a look at this message /message/207904# 207904 https://communities.intel.com/message/207904# 207904.
JPMontero_Intel
