Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Convert temeprature to *C
What am I doing wrong. I believe i properly converted the code (Arduino -> C) from that example:
http://www.seeedstudio.com/wiki/Grove_-_Temperature_Sensor_V1.2# Download Grove - Temperature Sensor V1.2 - Wiki
or even (Python -> C)
https://github.com/Seeed-Studio/Grove_Starter_Kit_for_BBG/blob/master/grove_temperature_sensor.py Grove_Starter_Kit_for_BBG/grove_temperature_sensor.py at master · Seeed-Studio/Grove_Starter_Kit_for_BBG · GitHub
but I think that values are wrong.
Here my code:
int get_temp_in_celcius(void)
const int B=4255;
int a;
a = mraa_aio_read(temp);
float R = 1023.0/((float)a)-1.0;
R = 100000.0*R;
float temperature=1.0/(log(R/100000.0)/B+1/298.15)-273.15; // looks ok: http://www.seeedstudio.com/wiki/images/a/a1/NCP18WF104F03RC.pdf http://www.seeedstudio.com/wiki/images/a/a1/NCP18WF104F03RC.pdf
printf("temp: %f\n",temperature);
return 20; /*I know*/
It prints about 15*C but I know here is much hotter.
I would appreciate any support.
Paweł
Community Manager
Hi Pawek,
I believe the code translated to C should look like the following:
# include
# include
# include
# include "mraa/aio.h"
int main()
mraa_aio_context adc_a0;
float adc_value = 0.0;
const int B=4255;
adc_a0 = mraa_aio_init(0);
if (adc_a0 == NULL)
return 1;
for (;;)
adc_value = mraa_aio_read_float(adc_a0);
float R = 1023.0/(adc_value)-1.0;
R = 100000.0*R;
printf("It is : %f\n degrees",temperature);
sleep(1);
mraa_aio_close(adc_a0);
return MRAA_SUCCESS;
Nevertheless, I don't have access to that sensor so I didn't try it. I did compile it and run it, but as expected the values were negative (~-90) because there was nothing connected. The ADC should be working but I'm not sure about the math, I just copied and pasted that part.
I hope this helps.
-Peter.
Community Manager
Hi Peter,
I think our codes are almost exactly the same.
Except that you use mraa_aio_read_float(adc_a0); and I mraa_aio_read(temp) so I compared it:
As you can see my temperature readings are also wrong even thought I have plugged temp sensor in.
My aios initialization are in separated function, nevertheless it is called before get_temp_in_celcis().
Thanks for support,
Paweł
======================================EDIT========================================================
Ok, I changed VCC to 5 V. Now my algorithm (with reading to int) seems to return proper values.
