Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Corrections to IoT Grove Rotary Angle JavaScript sample
Jump to solution
The JavaScript sample on this page requires two corrections to work: https://software.intel.com/en-us/iot/sensor/grove-rotary-angle https://software.intel.com/en-us/iot/sensor/grove-rotary-angle
//Load mraa module var mraa = require("mraa");
//Instantiate Aio on Pin # 0.
var rotarySensor = new mraa.Aio(0);
//Read sensor data function readRotaryValue(){
Console.log ("Rotary Value: " + rotarySensor.read());
//should be console.log }
set Interval(readRotaryValue, 1000);
//should be setInterval
Change to:
//Instantiate Aio on Pin # 0. var rotarySensor = new mraa.Aio(0);
console.log("Rotary Value: " + rotarySensor.read()); }
setInterval(readRotaryValue, 1000);
Accepted Solutions
Highlighted
Re: Corrections to IoT Grove Rotary Angle JavaScript sample
Jump to solution
It's been fixed. Thanks for pointing it out Marvin.
Joe Butler
Highlighted
Jump to solution
Thank you. we will get this correct.
Ural
Highlighted
Jump to solution
Joe Butler
