Community
cancel
Showing results for
Search instead for
Did you mean:
MBelt1
Could you please help me to use HC-SR04 ultrasonic sensor in Intel Galileo 1G?
Jump to solution
In my class we have tried for many weeks to run this sensor with Python , but we couldn't. Someone could help me with some code to make it work in Python.
Tags (1)
Diego_V_Intel
Hello mafe,
I recommend you to check the following threads about ultrasonic sensors with Galileo. You will find useful information regarding how to properly wire the sensor in case it's a 3-pin sensor. You will also find tips shared by other users for 3-pin and 4-pin sensors:
The threads above discuss the use of the ultrasonic sensor from the Arduino side. Since you are using the sensor with Python, I recommend you to write a Python script based on the Arduino examples. The ultrasonic sensor uses the pulseIn() method, you could check how this method works and try to write a similar method in Python based on the Arduino version. Please check the following thread: . The user in that thread asked a similar question, she wanted to use the sensor in C++ so she ported the pulseIn() method from Arduino to hers own version to be used in C++. You might want to do a similar approach but using Python instead.
Additionally, there is an example code available for C++ here: https://github.com/intel-iot-devkit/upm/blob/master/examples/c%2B%2B/hcsr04.cxx upm/hcsr04.cxx at master · intel-iot-devkit/upm · GitHub. Unfortunately, there is not a Python version of it, but you could check the library used in that example and try to port it to Python.
I hope you find these suggestions useful.
Diego.
Diego_V_Intel
Hello mafe,
Diego.
