hello,
I am trying to install cp-abe on my galileo gen-2 while running make command i am having these errors as:
make
make all-recursive
make[1]: Entering directory '/home/root/files/gmp-6.1.2'
Making all in tests
make[2]: Entering directory '/home/root/files/gmp-6.1.2/tests'
Making all in .
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests'
make[3]: Nothing to be done for 'all-am'.
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests'
Making all in devel
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/devel'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/devel'
Making all in mpn
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/mpn'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/mpn'
Making all in mpz
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/mpz'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/mpz'
Making all in mpq
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/mpq'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/mpq'
Making all in mpf
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/mpf'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/mpf'
Making all in rand
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/rand'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/rand'
Making all in misc
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/misc'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/misc'
Making all in cxx
make[3]: Entering directory '/home/root/files/gmp-6.1.2/tests/cxx'
make[3]: Leaving directory '/home/root/files/gmp-6.1.2/tests/cxx'
make[2]: Leaving directory '/home/root/files/gmp-6.1.2/tests'
Making all in mpn
make[2]: Entering directory '/home/root/files/gmp-6.1.2/mpn'
/bin/sh ../libtool --mode=compile --tag=CC ../mpn/m4-ccas --m4="m4" gcc -std=gnu99 -c -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_`echo add_n | sed 's/_$//'` -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -Wa,--noexecstack `test -f 'add_n.asm' || echo './'`add_n.asm
libtool: compile: ../mpn/m4-ccas --m4=m4 gcc -std=gnu99 -c -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_add_n -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -Wa,--noexecstack add_n.asm -fPIC -DPIC -o .libs/add_n.o
../libtool: line 1766: ../mpn/m4-ccas: Permission denied
Makefile:768: recipe for target 'add_n.lo' failed
make[2]: *** [add_n.lo] Error 1
make[2]: Leaving directory '/home/root/files/gmp-6.1.2/mpn'
Makefile:956: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/root/files/gmp-6.1.2'
Makefile:775: recipe for target 'all' failed
make: *** [all] Error 2
help...
Hi ChiChi,
Thanks for your interest in the Intel Galileo Platform.
When you say "I am trying to install cp-abe" do you mean you are trying to install the Advanced Crypto Software Collection? If you are, could you be so kind to provide me the guide that you are following.
I found this link http://acsc.cs.utexas.edu/cpabe/ Advanced Crypto Software Collection , but we want to be sure that we are following the same steps as you, so we can replicate your issue.
We will be waiting for your reply, have a nice day!
-Jose P.
hello Jose,
yes, I am trying to install the libraries from the link you have mentioned above in my galileo gen2 and the libraries are-
1. cpabe-0.11
2. libswabe-0.9
3. gmp-6.1.2
4. pbc-0.5.14
I am preferring a video to install it here is the link-
https://www.youtube.com/watch?v=aXDQ1J8kRw0 Ciphertext Policy Attribute Based Encryption (CP-ABE) installation in Ubuntu OS - YouTube
Hi ChiChi,
I follow the guide that you share (https://www.youtube.com/watch?v=aXDQ1J8kRw0 Ciphertext Policy Attribute Based Encryption (CP-ABE) installation in Ubuntu OS - YouTube ) and I already install cp-abe on my Galileo Gen 2! I will try my best to summarize the steps that I took in order to install this software:
Step 1:
I download the gmp, pbc, libbswabe and cpabe files, then I use WinSCP in order to transfer these files to my Galileo.
Step 2: Run the command: opkg update
Step 3: This the longest step I will explain file by file.
GMP file:
1) Navigate to gmp-6.1.2
2) Run the command: ./configure (At the beginning it gave an error of permission denied, so I used the command: chmod +x configure).
3) Run again the command: ./configure ( Got another error of permission with the m4-css file, so I used the cmod +x m4-css).
3) Run the command: make
4) Run the command: make install.
PBC file:
1) Navigate to pbc-0.5.14
2) Run the command: ./configure (Again had to run the command: chmod +x configure).
Libbswabe file:
1) Navigate to libbswabe-0.9
3) Run the command: make (Another error with permissions had to run the command: chmod +x mkinstalldirs and the command: chmod +x install-sh).
Cpabe file:
1) Navigate to cpabe-0.11
After this you should have installed cp-abe in your Galileo!
We hope you have a nice day!
-Jose P.
Hi ChiChi,
Were you able to install cp-abe in your Galileo? Please let me know in order to assist you.
Have a nice day!
-Jose P.
no, i was not able to install while in my gmp file installation, i am not getting any m4-css error but after running make i am getting these error
libtool: compile: gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_add -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -c add.c -o add.o >/dev/null 2>&1
/bin/sh ../libtool --tag=CC --mode=compile gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_`echo add_1 | sed 's/_$//'` -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -c -o add_1.lo add_1.c
libtool: compile: gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_add_1 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -c add_1.c -fPIC -DPIC -o .libs/add_1.o
libtool: compile: gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I.. -D__GMP_WITHIN_GMP -I.. -DOPERATION_add_1 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -c add_1.c -o add_1.o >/dev/null 2>&1
make[2]: Leaving directory '/home/root/gmp-6.1.2/mpn'
make[1]: Leaving directory '/home/root/gmp-6.1.2'
and even if i execute chmod +x m4-css i am getting this error
chmod: cannot access 'm4-css': No such file or directory within my gmp folder
Hi ChiChi,
If you check your permission error, you will see that the file m4-ccas is located in the directory mpn, so you need to use the following commands:
1) cd gmp-6.1.2/mpn
2) chmod +x m4-ccas
Please let me know if this fixes your error.
I will be waiting for your reply, have a nice day!
-Jose P.
hello , i have installed cp-abe but when executing cpabe-setup command. It's giving illegal instructions.
regards
chichi
Hi ChiChi,
Unfortunately, executing Cp-abe on the Galileo is out of the scope of our support. Nevertheless, I would encourage you to contact the developers of Advanced Crypto Software Collection, you can find their email on this website http://acsc.cs.utexas.edu/cpabe/ Advanced Crypto Software Collection . Maybe they will be able to provide you further assistance.
-Jose P.
hello, i ran make check in my gmp and found that i am getting failedd scripts running can you please tell me how can i fix them?? didn't heard anything from their developer's.
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom22 t-toom22.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom22 t-toom22.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 6909 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom22
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom32 t-toom32.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom32 t-toom32.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7008 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom32
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom33 t-toom33.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom33 t-toom33.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7107 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom33
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom42 t-toom42.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom42 t-toom42.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7206 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom42
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom43 t-toom43.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom43 t-toom43.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7305 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom43
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom44 t-toom44.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom44 t-toom44.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7404 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom44
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom52 t-toom52.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom52 t-toom52.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7503 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom52
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom53 t-toom53.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom53 t-toom53.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7602 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom53
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom54 t-toom54.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom54 t-toom54.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7701 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom54
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom62 t-toom62.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom62 t-toom62.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7800 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom62
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom63 t-toom63.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom63 t-toom63.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7899 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom63
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom6h t-toom6h.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom6h t-toom6h.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 7998 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom6h
/bin/sh ../../libtool --tag=CC --mode=link gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o t-toom8h t-toom8h.o ../../tests/libtests.la ../../libgmp.la
libtool: link: gcc -std=gnu99 -m32 -O2 -pedantic -fomit-frame-pointer -mtune=pentium-mmx -march=pentium-mmx -o .libs/t-toom8h t-toom8h.o ../../tests/.libs/libtests.a /home/root/gmp-6.1.2/.libs/libgmp.so ../../.libs/libgmp.so -Wl,-rpath -Wl,/usr/local/lib
../../test-driver: line 107: 8097 Illegal instruction "$@" > $log_file 2>&1
FAIL: t-toom8h
/bin/sh ../../lib...
Hi ChiChi,
This seems to be an error with the gmp-6.1.2 library, I would encourage you to report this bug to mailto:gmp-bugs@gmplib.org gmp-bugs@gmplib.org.
-Jose P.
