Community
cancel
Showing results for
Search instead for
Did you mean:
PMora5
Create image using wic
I'm using BSP to build my custom kernel and I was wondering how to proper use the provided wic tool to generate a .direct image.
The way I used was wic create directdisk -e image-full , the command ran with no errors, but the generated image didn't boot on Galileo Gen 2.
P.S. this tutorial https://software.intel.com/en-us/blogs/2015/03/04/creating-a-yocto-image-for-the-intel-galileo-board... IoT - Creating a Yocto image for the Intel® Galileo board using split layers | Intel® Software of how to use wic, don't work either on BSP.
Community Manager
We want to try and replicate your case. Which BSP are you using and what commands have you followed so far?
-Sergio
PMora5
Hey Sergio,
I'm using BSP 1.2.1.1 on a Ubuntu 12.04 host (tried and failed when I ran ./setup.sh on a Debian 8 host).
I've followed the BSP guide... ./setup.sh then source ./oe-init-build-env and then bitbake image-full (didn't make any changes).
Since it built successfully, I tried to generate a .direct image using wic tool by running this command wic create directdisk -e image-full.
The output of such command was:
Checking basic build environment...
Done.
Creating image(s)...
Info: The new image(s) can be found here:
/var/tmp/wic/build/directdisk-201606160634-sda.direct
The following build artifacts were used to create the image(s):
ROOTFS_DIR: /home/pksm/bsp/meta-clanton_v1.2.1.1/build/tmp/work/quark-poky-linux/image-full/1.0-r0/rootfs
BOOTIMG_DIR: /home/pksm/bsp/meta-clanton_v1.2.1.1/build/tmp/sysroots/quark/usr/share
KERNEL_DIR: /home/pksm/bsp/meta-clanton_v1.2.1.1/build/tmp/sysroots/quark/usr/src/kernel
NATIVE_SYSROOT: /home/pksm/bsp/meta-clanton_v1.2.1.1/build/tmp/sysroots/x86_64-linux
The image(s) were created using OE kickstart file:
/home/pksm/bsp/meta-clanton_v1.2.1.1/scripts/lib/image/canned-wks/directdisk.wks
I'd like to know how to proper generate an image with wic or other tool...similar to the images Intel provides, that are encapsulated on a single file (usually *.direct).
Community Manager
Thank you for posting the information we requested. We'll run some tests and let you know our results soon.
-Sergio
Community Manager
We have attempted without success to build the galileo image on Ubuntu 14.04. We received the following error after running bitbake:
configure: exit 1
ERROR: oe_runconf failed
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_configure
The tutorial you're following is used to build split layers image for Galileo using the IoT image, that tutorial was not tested nor validated with Quark image 1.2.1.1; because of this, this combination is not supported.
-Sergio
PMora5
Hi Sergio,
Thank you for testing it.
Just one follow up question, when Intel releases a new image for download is usually a single file with *.direct extension. I was wondering which tool do you use to produce such image, I thought it was with wic tool, but I was wrong.
Paula
FTinetti
Honored Contributor I
PaulaK wrote:
Hi Sergio,
Paula
I think this is a good question for a new thread, actually. I would use "/thread/103261 I have the same question/thread/103261 " on that question/thread...
Fernando.
Community Manager
PMora5
Thanks Sergio, I'll try it and give a feedback later.
