Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Creating Java applications on Galileo
Community Manager
What is the easiest way to develop java programs on the Galileo? Should/Can I use the Eclipse IDE the comes with the IoT DevKit?
Many thanks
Matthias_H_Intel
I wonder whether any of the available downloadable images have Java support built in - maybe the Debian* one?
If you need to have Java support on a Yocto* build my blog might be of interest for you:
https://software.intel.com/en-us/blogs/2014/04/04/some-hints-on-yocto-builds-for-iot-devkit-example-... Some hints on Yocto builds for IoT devkit - example: adding Java JRE
AT9
There's at least one place I know of - folks from Intel-NTU Connected Context Computing Center in Taiwan have created a set of images (I think based on 0.7.5 BSP) with various JDK and Tomcat versions.
See here: http://ccc.ntu.edu.tw/index.php/news/40 Intel-NTU Connected Context Computing Center
