Folks,
I've tried to load the currently available Ubilinux to Edison a couple times over yesterday and I'm not having luck.
I've used both a Mac and PC to do this activity.
The downloadable archive is ubilinux-edison-150309.tar.gz
I retrieved that from: http://www.emutexlabs.com/ubilinux EmutexLabs
It looks like it flashes correctly. However, when loading, I can watch in the Linux startup a [FAILED] Failed loading kernel module.
Finally, it DOES get to a login prompt, however that prompt is not Debian...
Poky (Yocto Project Reference Distro) 1.6 edison ttyMFD2
Anyone else having this problem? It almost looks like their ARCHIVE is delivering Yocto instead of Ubilinux. Maybe an OLDER archive is correct? I can't seem to find anything but the button on the EmutexLabs site which is that 150309 version.
Thoughts?
Hi Cale-Hoopes,
Are you following http://www.emutexlabs.com/ubilinux/29-ubilinux/218-ubilinux-installation-instructions-for-intel-edis... these instructions to install the image? If you do and you still have problems, I suggest you to post your question in http://www.emutexlabs.com/forum/index EmutexLabs because they are the owners of the Ubilinux image.
Kind regards,
Charlie
Hey! I know it's not an Intel issue, but I thought I'd throw it out to the community.
I've certainly posted on the EmutexLabs forum as well. I'm basically just trying to get the community to let me know if they've had success. I think something with their image is wrong, honestly and I just want to know if other users have had the problem.
I have used those instructions and I've tried these instructions as well:
https://learn.sparkfun.com/tutorials/loading-debian-ubilinux-on-the-edison Loading Debian (Ubilinux) on the Edison - learn.sparkfun.com
Hi Cale-Hoopes,
don't you think it's somewhat odd to bug Intel who declared Yocto as their supported linux distro with questions about (unsupported) other distros?
Of course the http://www.emutexlabs.com/ubilinux EmutexLabs archive is not delivering Yocto. Your installation has simply failed. Besides, this issue has been discussed in the community before :
Best,
WX3080
I thought this was COMMUNITY. But if this is only for issues, sorry I posted here. Apparently, there's no place to discuss if you're having problems. I've not had a successful install of this and I wondered if anyone had success with the current release is all.
Some information here... as soon as it gets to ROOTFS, it throws an error about "Cannot allocate memory of size 1610612736 (exactly the 1536MiB in the BIN file for the ext4). I'm wondering if my partitioning is failing in some way - it doesn't seem to partition correctly.
Hi Cale-Hoopes,
I think the steps from http://www.emutexlabs.com/ubilinux/29-ubilinux/218-ubilinux-installation-instructions-for-intel-edis... EmutexLabs should work without problems, are you doing changes in the partitions of the image?
I suggested you to contact http://www.emutexlabs.com/forum/index EmutexLabs because they are the owners and experts with this image, so if there is something wrong with your install they should know the source of the problem.
Now as I said, their steps should work without problems. Have you tried with the Yocto image to see if the board boots correctly?
Charlie
Thanks for the reply! Yep, I've tried on Mac & PC (but not linux as I don't have a hardware install - I might try from a VM).
I am working with them on this. Yep, I actually have confirmed I can successfully reload the Yocto image so I'm confident it's not BRICKED.
Seems like its definitely some kind of "size" problem with the download specifically. They say they haven't seen this problem. I have this problem even with their 2014 install (was able to find it after all).
I'm actually wondering if there's some kind of problem where the file system is not being properly partitioned or something.
Anyhow, thanks for the suggestion. I really wanted to share this to see if anyone else was running into this.
