Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Custom OS / Hardware Questions
Jump to solution
Hi! I'm a primary developer contributing to the open source called MOSA Project (www.mosa-project.org). Basically, a .NET optimizing compiler tool chain and bare metals operating system. We would like to target the Galileo platform and have a few questions to get started:
  1. Can Galileo boot from a SD card using either a Grub or Syslinux boot loader? Any special considerations?
  2. Does Galileo continue to use the traditional serial I/O ports (example, at 0x3F8)? If not, where can we find the serial specifications?
  3. And how can the General Purpose I/O (GPIO) pins be accessed?
Thanks in advance!
Sergio_A_Intel
Yes, the Galileo can boot from an SD card. It's recommended you use one of the images provided in the software downloads website https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone .
Using one of the images on the SD card will allow you to boot using the grub. You can see more information here https://software.intel.com/en-us/get-started-galileo-linux-step1 IoT - Step 1: Make a bootable micro SD card | Intel® Developer Zone
If you use one of the provided Linux images you can access the gpios through the Linux console. There is a variety of options to configure the various gpios. You'll find more information in the directory /sys/class/gpio/.
Take a look at this guide http://www.emutexlabs.com/component/content/article?id=203:getting-started-with-intel-galileo-gen-2 EmutexLabs . It is a very complete guide that describes most of the general aspects of the board very clearly.
Sergio
Sergio_A_Intel
Sergio
Community Manager
I also found the http://download.intel.com/support/processors/quark/sb/quarkdatasheetrev02.pdf Intel® Quark™ SoC X1000 Datasheet contains very detailed information on how to control the pins via GPIO PCI Controller.
