i trie to make a custom .bb file for my board. i can run bitbake without an error but i'm not able to copy some pre compiled .so files to my device.
SUMMARY = ""
DESCRIPTION = ""
HOMEPAGE = ""
LICENSE = "GPLv2"
LIC_FILES_CHKSUM = "file://${WORKDIR}/COPYING;md5=f74cdfd6d7e3a11c3e776b27e7cfa586"
SRC_URI = "file://tam_modem_start; \
file://tam_modem_start.service; \
file://tam_gateway_upload; \
file://tam_gateway_upload.service; \
file://tam_gateway_upload_telematic_hub.json; \
file://intel_mcu.bin; \
file://libazure_functions.so; \
file://libble.so; \
file://libble_c2d.so; \
file://libble_printer.so; \
file://libhello_world.so; \
file://libidentity_map.so; \
file://libiothub.so; \
file://liblogger.so; \
file://libnative_module_host.so; \
file://libsimulated_device.so; \
file://libsqlite.so; \
file://libtam_gateway.so; \
file://libTAMGNSS.so; \
file://libXBee.so; \
file://COPYING;"
PROVIDES = "tam"
DEPENDS = " \
mraa \
azure-iot-gateway-sdk \
# specify where to get the files
S = "${WORKDIR}"
# SYSTEMD_SERVICE
# When inheriting the systemd class, this variable specifies the systemd service name for a package.
# When you specify this file in your recipe, use a package name override to indicate the package to which the value applies.
# Here is an example from the connman recipe:
# SYSTEMD_SERVICE_${PN} = "connman.service"
SYSTEMD_SERVICE_${PN} = " \
tam_modem_start.service \
tam_gateway_upload.service \
FILES_${PN} = "${systemd_unitdir}/system/*"
FILES_${PN} += "${bindir}/*"
FILES_${PN} += "${exec_prefix}/bin/*"
FILES_${PN} += "${libdir}/*.so"
FILES_${PN} += "${libdir}/lib*.so.*"
FILES_${PN} += "${base_prefix}/*"
FILES_${PN} += "${exec_prefix}/lib/*"
FILES_${PN}-dbg += "${exec_prefix}/lib/.debug"
FILES_${PN}-dbg += "${exec_prefix}/lib/firmware/.debug"
FILES_${PN}-dbg += "${exec_prefix}/bin/.debug"
ALLOW_EMPTY_${PN} = "1"
do_install() {
mkdir -p 0755 ${D}${exec_prefix}/lib/firmware/
# mkdir -p 0755 ${D}${exec_prefix}/lib/
# mkdir -p 0755 ${D}${exec_prefix}/bin/
# install -d ${D}${exec_prefix}/lib
# install -d ${D}${exec_prefix}/bin
install -d ${D}${exec_prefix}/lib/firmware
install -d ${D}${systemd_unitdir}/system
install -c -m 0777 ${WORKDIR}/tam_modem_start.service ${D}${systemd_unitdir}/system
install -m 0777 ${WORKDIR}/tam_modem_start ${D}${exec_prefix}/bin
install -c -m 0777 ${WORKDIR}/tam_gateway_upload.service ${D}${systemd_unitdir}/system
install -m 0777 ${WORKDIR}/tam_gateway_upload ${D}${exec_prefix}/bin
install -m 0777 ${WORKDIR}/tam_gateway_upload_telematic_hub.json ${D}${exec_prefix}/bin
install -m 0777 ${WORKDIR}/intel_mcu.bin ${D}${exec_prefix}/lib/firmware
install -m 0777 ${WORKDIR}/libazure_functions.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libble.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libble_c2d.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libble_printer.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libhello_world.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libidentity_map.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libiothub.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/liblogger.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libnative_module_host.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libsimulated_device.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libsqlite.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libtam_gateway.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libTAMGNSS.so ${D}${exec_prefix}/lib
install -m 0777 ${WORKDIR}/libXBee.so ${D}${exec_prefix}/lib
# ln -s 0777 tam_modem_start.service ${D}${systemd_unitdir}system/multi-user.target.wants/tam_modem_start.service
the starnge thing is that tam_modem_start, tam_modem_start.service, tam_gateway_upload, tam_gateway_upload.service, tam_gateway_upload_telematic_hub.json, intel_mcu.bin work fine to copy only all the .so files are not on my target device.
does anybody has a hint on that ?
Hi Gerrik84k,
To be honest, this question related with custom images is beyond of our support scope. Having said that, I will try my best to help you with this.
The first time that I checked your .bb file didn't see any error or missing line, but I will investigate more about it, and I will contact you if I have updates.
I appreciate your patience.
Leonardo R.
Hi Gerrik84k,
I just want to let you know that I'm still trying to find the issue, I will contact you when I have something helpful.
Have a nice day.
Leonardo R.
thanks for that
Hi Gerrik84k,
I was investigating about this, and I have found this link: http://yocto.yoctoproject.narkive.com/GgCFmLCY/recipe-to-copy-precompiled-binaries-to-root-image
It seems that the user had a similar issue, and he solved it adding the lines:
FILES_${PN} += "${libdir} /etc" FILES_${PN}-dbg += "${libdir}/.debug /etc/.debug" FILES_SOLIBSDEV = ""
I haven't tried that yet, but I recommend you to check that link and try it.
I really hope this works for you, we are trying our best to help you in this case that is out of our support.
Have a nice day.
Leonardo R.
