I've been trying to customize the kernel on the latest release (release 3.0 of Yocto sources) and am stumbling on where to copy the .config file. The i386_edison_defconfig seemed to be the logical place from what I gleaned from the recipes, however when I issue the bitbake edison-image following overwriting the i386_edison_defconfig it tell me that it has nothing to do...
All of the documents that I have found make reference to outdated directory structures so a link to the updated document (that makes reference to the linux-externalsrc portion of the tree) or any guidance would be greatly appreciated. To be clear, I am able to generate the new .config correctly, the question is simply where I should put it and/or which bitbake incantation I should use to get it to rebuild the kernel with the driver I need to add.
Any help / guidance would be greatly appreciated.
Hello mpapini,
Let me try to do some tests and see if I can replicate this behavior. I will get bac to you as soon as as I can.
Peter.
Peter,
Using http://alextgalileo.altervista.org/blog/reconfiguring-linux-kernel-adding-drivers-galileos-linux-ima... Alex's guide for galileo I was able to build the driver module, however, the driver won't install since it says that the module dep of "kernel-3.10.17-poky-edison+" can't be satisfied ... and in fact a "uname -r" shows "3-10.17-yocto-standard" so now I have the issue that somewhere the kernel names get crossed.
To facilitate you reconstructing my chaos here's what I did ...
1) Download latest iot tarball and extract
2) ran setup.sh with dl & sstate directories
3) cd to directory that the script tells me to ...
4) source poky/oe-init-build-env
5) do a full bitbake (bitbake edison-image), which asides from the already known and resolved mqtt runs without a hitch.
6) bitbake -c menuconfig linux-externalsrc
7) mark driver as module and save config. (in my case the bq27x00)
8) copy just the changed lines from i386_edison_defconfig
9) force a recompile of linux-externalsrc (bitbake -f -c compile linux-externalsrc) - I tried deploy but it didn't work for me (i.e., yocto doesn't have a rule for deploy)
10) bitbake edison-image
The module seems to be included with the modules ipk, but even when I just built it, the dependancy for the wrong kernel was there...
I have a new clean build running and will be able to experiment again tomorrow.
Thanks for your help - Mario
Anyone been able to modify the kernel config and get it to build correctly?
Anyone have any clues how to re-invoke bitbake after updating the config or defconfig?
Anyone at Intel able to point me in the right direction? Even if you don't re-create the problem, what are the steps I should be following because the BSP User's Guide doesn't seem to work anymore.
Hello Mario,
I'm sorry for the delay in my reply. This is what we did for the image 3.0:
On the file iot-devkit-yp-poky-edison-20160315/poky/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-externalsrc.bb.
Comment line 17 and replace it with:
cp "/.config" "${B}/.config"
Let me know if it works, we'll be glad to help you if otherwise.
Peter.
Thanks Peter it now works. For future reference, here are the steps that I followed to customize the kernel (based on the README, other discussions in the forum and Peter's comment):
1) unzip iot-devkit-yp-poky-edison-20160315.zip
2) cd iot-devkit-yp-poky-edison-20160315/poky/
3) source oe-init-build-env ../build_edison/
4) edit iot-devkit-yp-poky-edison-20160315/build_edison/conf/local.conf to comment out the following lines (starting at line 223):
# PACKAGECONFIG_append_pn-qemu-native = " sdl" line 223
# PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
# ASSUME_PROVIDED += "libsdl-native"
5) bitbake edison-image u-boot
6) bitbake virtual/kernel -c menuconfig & configure your kernel
7) cp iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config iot-devkit-yp-poky-edison-20160315/poky
8) edit linux-externalsrc.bb: cp "${EDISONREPO_TOP_DIR}/.config" "${B}/.config"
9) bitbake edison-image u-boot
10) ../poky/meta-intel-edison/utils/flash/postBuild.sh .
11) zip -r toFlash.zip toFlash or install module .ipk (if you built a module) from iot-devkit-yp-poky-edison-20160315/build_edison/tmp/deploy/ipk/edison
Please note that all paths are relative to where iot-devkit... is installed. Hope this helps someone else.
Mario
Hi
When I am performing the 7th step mentioned above it says that there is no file existing. I checked in the folder also and I couldn't find any file or folder by the name ".config". Please let me know the solution to it.
Nagarjuna
It gives the following response when i run the 7th step.
configure: WARNING: you should use --build, --host, --target
checking whether to use symlinks for manpages... no
checking whether to compress the manpages... no
checking whether to add a package name suffix for the manpages... no
checking for your-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for inline... inline
checking how to run the C preprocessor... ERROR: Only one copy of bitbake should be run against a build directory
gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dirent.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking if the compiler understands -pipe... yes
checking for building with threads... no (default)
checking for sin... no
checking for main in -lieee... yes
checking for main in -linet... no
checking net/errno.h usability... no
checking net/errno.h presence... no
checking for net/errno.h... no
checking for connect... yes
checking for gethostbyname... yes
checking how to build libraries... shared
checking for your-ranlib... no
checking for ranlib... ranlib
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking if compiler supports visibility "hidden"... yes
checking if rpath support is requested... yes
checking system version... Linux-3.13.0-24-generic
checking for dlopen in -ldl... yes
checking for your-ar... no
checking for ar... ar
checking for build with symbols... no
checking for required early compiler flags... _LARGEFILE64_SOURCE
checking for 64-bit integer type... using long
checking whether byte ordering is bigendian... no
checking for getcwd... yes
checking for opendir... yes
checking for strtol... yes
checking for waitpid... yes
checking for strerror... yes
checking for getwd... yes
checking for wait3... yes
checking for uname... yes
checking for realpath... yes
checking for getaddrinfo... yes
checking for working getaddrinfo... yes
checking sys/modem.h usability... no
checking sys/modem.h presence... no
checking for sys/modem.h... no
checking termios vs. termio vs. sgtty... termios
checking for fd_set in sys/types... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for gmtime_r... yes
checking for localtime_r... yes
checking for mktime... yes
checking tm_tzadj in struct tm... no
checking tm_gmtoff in struct tm... yes
checking long timezone variable... yes
checking for struct stat.st_blocks... yes
checking for struct stat.st_blksize... yes
checking for blkcnt_t... yes
checking for fstatfs... yes
checking for working memcmp... yes
checking for memmove... yes
checking for strstr... yes
checking proper strstr implementation... ok
checking for strtoul... yes
checking proper strtoul implementation... ok
checking for strtod... yes
checking proper strtod implementation... ok
checking for strtod... (cached) yes
checking for Solaris2.4/Tru64 strtod bugs... ok
checking for mode_t... yes
checking for pid_t... yes
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for socklen_t... yes
checking for intptr_t... yes
checking for uintptr_t... yes
checking for opendir... (cached) yes
checking union wait... yes
checking for strncasecmp... yes
checking for BSDgettimeofday... no
checking for gettimeofday... yes
checking for gettimeofday declaration... present
checking whether char is unsigned... no
checking signed char declarations... yes
checking for a putenv() that copies the buffer... no
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking whether to use nl_langinfo... yes
checking for chflags... no
checking isnan... yes
checking for fts... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/filio.h usability... no
checking sys/filio.h presence... no
checking for sys/filio.h... no
checking system version... (cached) Linux-3.13.0-24-generic
checking FIONBIO vs. O_NONBLOCK for nonblocking I/O... O_NONBLOCK
checking whether to use dll unloading... yes
checking for timezone data... /usr/share/zoneinfo
checking whether to enable DTrace support... no
checking if the C stack grows upwards in memory... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating dltest/Makefile
config.status: creating tclConfig.sh
[2]- Exit 1 bitbake virtual/kernel -c menuconfig
There is an error that says, that only one copy of bitbake should be run against build directory. What does it mean and how could I solve it? Please help me with this.
Nagarjuna
Hello nag96chidara,
If you did not change the name of the file it'll be called .config and if you haven't changed your PC's settings, it will be hidden, so I suggest you to look for it using the terminal with the command ls -la.
-Peter.
