Community
cancel
Showing results for
Search instead for
Did you mean:
GZoje
D2000 TI BoosterPack SIL ?
Hello to everyone,
Just got my Quark MCU Developer Kit D2000 and just wondering why there is no documentation
related to TI Boosterpack SIL.Only found variations of the following block diagram
( http://hackerboards.com/intel-aims-15-dollar-quark-d2000-dev-kit-at-iot-devices/) marked as Alternate Interface.
And if you look up TI resources you only can find that it is BoosterPack Module Pinout Standard for 20 pins.
So I am guessing right that I can BoosterPack interfaces only with I2C and UART ?
Thanks in advance for any feedback
Gottfried
Community Manager
Thanks for contacting us! We'll investigate this a little bit more, and as soon as I found something helpful I'll post that here. We'll appreciate your patience.
-Yermi
Michelle_C_Intel
Hi Gottfried,
Have you had a look at the User Guide http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/quark-developer-kit-d2000-u... Intel® Quark™ Microcontroller Developer Kit D2000: User Guide . Table 5 includes the Booster Pack Pin Mapping.
-Michelle.
GZoje
Michelle,
Thanks for your reply and I will check it out.
But when I talked from missing documentation I was not thinking about Pin Mapping alone.
One example Arduino shield / TI Boosterpack setup documented would have been great.
Myself I will use Sensor Hub BoosterPack and try to get a I2C communication running like on a MSP430
Rgds Gottfried
Community Manager
Hi Gottfried,
I am not aware of any document like the one you are mentioning, so I'll pass your suggestion to our appropriate team. Moreover, if you share your results in the community it would be very helpful for other users, and also, if you need more help we'll be happy to help you.
-Yermi
GZoje
Yermi,
Thanks for your answer and yes when I get it working I will share with community.
What I meant was documents similar to this one mentioned below for Intel Galileo and Arduino shields
I have no way to verify if they are genuine Intel documents or in case of Arduino.cc page authorized .
http://lib.chipdip.ru/033/DOC001033562.pdf
https://www.arduino.cc/en/ArduinoCertified/IntelGalileo
Would be great to have them for Arduino and TI Boosterpack for D2000 as well and (Enabling-dht11-humidity-sensor-application-note.pdf) for a sensor is already there as reference
Best regards
Gottfried
Community Manager
Hi Gottfried,
Thank you very much for clarifying which documents you are mentioning. This one (http://lib.chipdip.ru/033/DOC001033562.pdf http://lib.chipdip.ru/033/DOC001033562.pdf) is an official Intel document and the other one (https://www.arduino.cc/en/ArduinoCertified/IntelGalileo https://www.arduino.cc/en/ArduinoCertified/IntelGalileo) is Arduino documentation based in the Intel Galileo documentation.
However, I would like to know if the document you would like to have for the D2000 would be like this http://www.intel.com/content/www/us/en/support/boards-and-kits/000020775.html Shield Testing Report for Intel® Galileo Board, Intel® Galileo Gen 2 Board, and Intel® Edison Board.
-Yermi
Community Manager
Hi Gottfried,
I'm wondering if you saw this document http://www.intel.com/content/www/us/en/support/boards-and-kits/000020775.html Shield Testing Report for Intel® Galileo Board, Intel® Galileo Gen 2 Board, and Intel® Edison Board. Is this what you are looking for D2000?
-Yermi
GZoje
Yermi,
Thanks a lot for this document it is really great and can clearly say that it answer my question related to Arduino.
But I want to get away in this tread from what I want as I already picked and decided my shields ( 1 Arduino , 1 TI Boosterpack )
and I will not change even if they are unsuitable for the D2000 Developer Kit.Also will use the D2000 anyway totally independent if the shields are working as education board
for Zephyr and your ISSM environment.My original idea for the post was just that you include a tested board for Arduino and Boosterpack in your Getting Started Guide.
In case of Arduino I guess it is pretty simple as there are so many boards out there.My search for TI 20 pin SIL was rather difficult so the real reason for my post.
Rgds Gottfried
Community Manager
Hi Gottfried,
Thank you very much for your suggestion. I've already passed your suggestion to our appropriate team.
As a reminder, if you have any questions or need more assistance, you can open another thread and we'll help you.
Have a nice day!
-Yermi
