Intel® Makers
9880 Discussions
D2000 Update ROM broken
mo_bri
I used the D2000 with the compass example and had the UART down another FTDI working fine. Then I tried the 2 UART example, and to do this I had to configure UART B to be used, I swapped over the links for J9,J10 and J11 to UART B. I then realized I hadn't downloaded the example firmware yet, so I swapped the links back and now I can not ever seem to download anything to it. I have tried on2 other fresh PCs (never installed D200 before), and I can se it is not a driver or OS or host PC issue.
It looks like it just can not seem to spin up the clock, and the JTAG handshake fails. :
Open On-Chip Debugger 0.8.0-dev-g377d3f24-dirty (2017-04-11-19:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
(likely Digital Pin 0)
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: quark_d2000.cltap: IR capture error; saw 0xff not 0x1
Warn : Bypassing JTAG setup events due to errors
adapter speed: 3 kHz
Error: Target not examined yet
Runtime Error: C:/IntelSWTools/ISSM_2016.2.094/tools/debugger/openocd//scripts/target/quark_d2000.cfg:90:
in procedure 'clk32M'
in procedure 'mww' called at file "C:/IntelSWTools/ISSM_2016.2.094/tools/debugger/openocd//scripts/target/quark_d2000.cfg", line 90
Trying from the telnet putty shell on 4444 locahost, and I tried this whilst running openocd with th d200 config file.
clk32m
jtag_recovery
But they all fail in the openocd window with :
http://openocd.sourceforge.net/doc/doxygen/bugs.html http://openocd.sourceforge.net/doc/doxygen/bugs.html
Running clk32M gives :
> clk32M
Runtime Error:
line 90
I cant load an rom, due to it says target not examined yet.
MuhamadSof_B_Intel
Hi marcuso,
You may refer here for JTAG recovery.
Soffi
MuhamadSof_B_Intel
Hi marcuso,
Soffi
mo_bri
Thanks this worked perfectly. I connected GND to D0 on the board and left it plugged in while I reflashed the ROM/Boot Loader with the ISSM (the Eclipse IDE) etc. I reset it a few times, and it bounced back to life.
