Intel® Makers
9881 Discussions
D2000 debug error with CRB JTAG
Community Manager
Host OS: Windows 7 64bit
Target: D2000 MCU on my board
Flash/Debug interface: CRB's JTAG
Code: ISSM "hello world" example
The target board is connected to host via CRB's JTAG connector,
I have used the OpenOCD command to flash MCU, but it show "write flash disabled", the log as below:
And I have used the "mdw"/"mww" command to read/write CTRL register, but it's look like not working.
The log as below:
Open On-Chip Debugger
> reset halt
JTAG tap: quark_d2000.cltap tap/device found: 0x0e786013 (mfg: 0x009, part: 0xe786, ver: 0x0)
Enabling lmt core tap
JTAG tap: quark_d2000.lmt enabled
target state: halted
target halted due to debug-request at 0x00000000 in real mode
> clk32M
adapter speed: 3 kHz
adapter speed: 1000 kHz
> del_flash0
0xb0100014: b0100014
> mdw 0xb0100018 20
0xb0100018: b0100018 b010001c b0100020 b0100024 b0100028 b010002c b0100030 b0100034
0xb0100038: b0100038 b010003c b0100040 b0100044 b0100048 b010004c b0100050 b0100054
0xb0100058: b0100058 b010005c b0100060 b0100064
> mww 0xb0100018 0
> mdw 0xb0100018 20
So far, I can't debug with ISSM or OpenOCD command,
Is there any suggestion about this issue? thanks!
Pedro_M_Intel
Hello AmandaLee,
As you can see in the introductory video in http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/issm-getting-started-windows-vide... Intel® Quark™ Microcontroller Getting Started on Windows*: Video if the USB driver has a bad installation it might produce issues when trying to flash or debug the board. In that case you should run the script install.bat found in C:\IntelSWTools\ISSM_2016.y.xxx\tools\debugger\driver\.
Have you tried this? Did it make any difference?
-Peter.
Community Manager
Hi Peter,
Thank you for your assistance.
I already installed usb driver(ISSM directory) and the OpenOCD Jtag device also be detect on host.
You can see the log that D2000 device ID can be found, but it can't be flash or debug.
Is there anything else i can try?
Thanks!
Amanda
Michelle_C_Intel
Hi Amanda,
What JTAG debugger are you using ? I see that you are using the default 'd2000_onboard.cfg' configuration file to connect to the board - Can you make sure you use the correct FDTI interface configuration file.
The configuration files for Olimex and Flyswatter are provided ....
Olimex :
bin\openocd.exe -f scripts\interface\ftdi\olimex-arm-usb-ocd-h.cfg -f scripts\board\quark_d2000.cfg
Flyswatter :
bin\openocd.exe -f scripts\interface\ftdi\flyswatter2.cfg -f scripts\board\quark_d2000.cfg
If you have the correct configuration file , you can also try connecting Digitial Pin 0 to GND , reset the board and try flashing again ....
Also , double chek your configuration ... the image below is one we used sucessfully with Olimex Debugger.
--Michelle.
Note : Remove all sleeves from Jumpers J9, J10, J11, J15, J17
Pin 1 – Black – (3.3V)
Pin 3 – Yellow - TRST
Pin 4 – Blue - GND
Pin 5 – White - TDI
Pin 7 – Red - TMS
Pint 9 – Green - TCK
Pin 13 – Orange TDO
