Intel® Makers
9868 Discussions
D2000 not recogonized LIBUSB_ERROR_NOT_SUPPORTED
Community Manager
Getting this error on Windows 10. When I plug in the device I get a COM port and a USB Serial Converter in device manager, but no ocd device. I've already tried installing drivers with tools/debugger/driver/install.bat and rebooting.
Community Manager
Hi ScottVT,
Take a look at this link: , another user had the same issue, the user just re-installed the driver and it worked, so I recommend you to do the same.
In my case it worked at the first time, I connected the board and I went to the C:\IntelSWTools\ISSM_2016.x.xxx\tools\debugger\driver directory, I double clicked the install.bat and I answered 'y'. I checked the driver in the device manager and OpenOCD JTAG device appears on the Universal Serial Bus devices category and I was able to flash the ROM without problems. The only difference is that I have Windows 8.1.
I personally recommend you to try to re-install the driver, if it doesn't work send me a screenshot of the error that you are getting to assist you in a better way.
I hope you find this information helpful.
-Leonardo
Community Manager
Hi ScottVT,
Was the information helpful? Did you re-install the OpenOCD driver? Did it work?
If you still have issues just let us know.
-Leonardo
