Community
cancel
Showing results for
Search instead for
Did you mean:
GBene1
D455 + T265 3d print mount?
Hi All,
Just got the new D455 realsense camera.
I have been using the D435 in conjunction with the t265 using the 3d printed mount for both cameras from the CAD file that was provided a while ago.
Is there any CAD file available for using the D455 together with the t265?
Seems key to get the two cameras lined up correctly so that the coordinate systems are aligned.
Thanks!
@MartyG_RealSense
Tags (3)
MartyG_RealSense
Hi there,
I am not able to handle T265 related enquiries unfortunately as other RealSense team members are responsible for that.   I recommend posting your request to the RealSense support forum at the link below so that the appropriate Intel team member can answer your question.  Thanks!
https://support.intelrealsense.com/hc/en-us
GBene1
