Community
cancel
Showing results for
Search instead for
Did you mean:
GCara1
DC power input J17-pin 4
i'm going to realize one custom interface for Intel edison mini breakout, i would like to use only the back connector, to connect all the devices. Can I connect the external DC power supply directly on DC IN on the pin n°4 of the J17 header? I'd like to not use the default J21 header, cause is situated on the top.
Pablo_M_Intel
Hi Giancarlo1809,
Yes, you can use the external power supply connected to J17-4 as stated in the Edison Hardware Guide.
Pablo
GCara1
Many thanks Pablo! I will use it connected pin J17-4 to a 12VDC power supply through an external Schottky barrier diode, used to prevent polarity inversion, cause i think that the internal protections diode are, bypassed when i use this kind of configuration. Is it right?
Giancarlo1809
Pablo_M_Intel
Hi Giancarlo1809,
By "this configuration" you mean applying 12V to J17-4? I've been looking at the schematics and I believe this is not the case. But it's always a good idea to prevent any possible issue, so I would suggest you to use the Schottky barrier diode for prevention.
Pablo
