Intel® Makers
9868 Discussions
DHT workaround for Galileo and Galileo Gen2 using 2 pins instead of one
sk23
New Contributor II
Hi ,
I was tying to use above code for Edison and DHT 22 sensor.
Please help me.
FTinetti
Honored Contributor I
Hi IoT_srinivas,
I've used the DHT11 with almost the same fix and behavior (some error eventually) in Galileo. Having said that, I think you should post Edison questions in the Edison forum:
HTH,
Fernando.
Community Manager
Hello IoT_srinivas,
What have you tried so far? And, what have you seen as output? I mean, could you please give us a description a little bit more complex, every detail you can provide will be of much help.
Peter.
sk23
New Contributor II
Hi ,
I tried the above code for DHT22 sensor on Intel Edison.
I was not getting temperature and humidity data.I was using IN4007 diode for above solution.
Please check the screen shoot for you reference.
sk23
New Contributor II
Hi ,
Reference link for code.
FTinetti
Hi IoT_srinivas,
Please try the attached code, I've used it with DHT11 in Galileo, but DHT22 seems to be "just" a better version of the DHT11 so I hopefully expect the sketch works. Suggested usage:
a) Unzip
b) Connect DHT data pin to pin3
c) Load&See
Take into account that Galileo (and I think Edison) does not seem to be well suited for DHT usage. There are lots of threads explaining why.
HTH,
Fernando.
FTinetti
Hi IoT_srinivas
Did you really use mraa based code in another IDE and solved your problem?
Fernando.
