Intel® Makers
9881 Discussions
DMA controller
JWigg
Hi !
Is there a list or sketch of the hardware configuration for the Intel Atom processor ? I need information about the DMA controller of the Edison-SoC.
asss
Valued Contributor II
root@edison:~# lshw
edison
description: Hand Held Computer
product: Merrifield (N/A)
vendor: Intel Corporation
version: A1
serial: N/A
width: 4294967295 bits
capabilities: smbios-2.6 dmi-2.6
configuration: boot=normal chassis=handheld family=N/A sku=N/A uuid=159CABA2-31B8-044E-90C6-D94B12BEDF80
*-core
description: Motherboard
product: BODEGA BAY
physical id: 0
version: 0
serial: N/A
slot: N/A
*-memory:0 UNCLAIMED
physical id: 0
*-bank UNCLAIMED
description: Chip 800 MHz (1.2 ns)
product: N/A
vendor: N/A
physical id: 0
serial: N/A
slot: N/A
width: 32 bits
clock: 800MHz (1.2ns)
*-memory:1
description: System Memory
physical id: a016
slot: System board or motherboard
capacity: 1GiB
*-cpu
description: CPU
product: Genuine Intel(R) CPU 4000 @ 500MHz
vendor: Intel Corp.
physical id: 5250
bus info: cpu@0
version: 6.10.8
serial: {removed}
slot: N/A
capacity: 500MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx rdtscp x86-64 constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc aperfmperf nonstop_tsc_s3 pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch ida arat epb dtherm tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms cpufreq
configuration: cores=1 enabledcores=1 id=0 threads=2
*-logicalcpu:0
description: Logical CPU
physical id: 0.1
width: 64 bits
capabilities: logical
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-logicalcpu:2
physical id: 0.3
width: 64 bits
*-logicalcpu:3
physical id: 0.4
width: 64 bits
*-logicalcpu:4
physical id: 0.5
width: 64 bits
*-logicalcpu:5
physical id: 0.6
width: 64 bits
*-logicalcpu:6
physical id: 0.7
width: 64 bits
*-logicalcpu:7
physical id: 0.8
width: 64 bits
*-logicalcpu:8
physical id: 0.9
width: 64 bits
*-logicalcpu:9
physical id: 0.a
width: 64 bits
*-logicalcpu:10
physical id: 0.b
width: 64 bits
*-logicalcpu:11
physical id: 0.c
width: 64 bits
*-logicalcpu:12
physical id: 0.d
width: 64 bits
*-logicalcpu:13
physical id: 0.e
width: 64 bits
*-logicalcpu:14
physical id: 0.f
width: 64 bits
*-logicalcpu:15
physical id: 0.10
width: 64 bits
*-firmware
description: BIOS
vendor: Intel(R) Ultra Mobile Firmware Development Kit
physical id: 4942
version: 542
date: 2015.01.21:18.19.48
capabilities: pci upgrade socketedrom acpi
*-memory:2 UNCLAIMED
physical id: 1
*-memory:3 UNCLAIMED
physical id: 2
*-pci
description: Host bridge
product: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 01
width: 32 bits
clock: 33MHz
*-generic:0
description: SD Host controller
physical id: 1
bus info: pci@0000:00:01.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm pcix bus_master cap_list
configuration: driver=sdhci-pci latency=64
resources: irq:0 memory:ff3fc000-ff3fc0ff
*-generic:1
physical id: 1.2
bus info: pci@0000:00:01.2
version: 01
width: 32 bits
clock: 33MHz
resources: irq:37 memory:ff3fa000-ff3fa0ff
*-generic:2
asss
root@edison:~# lshw
edison
version: A1
serial: N/A
*-core
product: BODEGA BAY
physical id: 0
version: 0
serial: N/A
slot: N/A
physical id: 0
*-bank UNCLAIMED
product: N/A
vendor: N/A
physical id: 0
serial: N/A
slot: N/A
width: 32 bits
*-memory:1
physical id: a016
capacity: 1GiB
*-cpu
description: CPU
vendor: Intel Corp.
physical id: 5250
bus info: cpu@0
version: 6.10.8
serial: {removed}
slot: N/A
capacity: 500MHz
width: 64 bits
*-logicalcpu:0
physical id: 0.1
width: 64 bits
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-logicalcpu:2
physical id: 0.3
width: 64 bits
*-logicalcpu:3
physical id: 0.4
width: 64 bits
*-logicalcpu:4
physical id: 0.5
width: 64 bits
*-logicalcpu:5
physical id: 0.6
width: 64 bits
*-logicalcpu:6
physical id: 0.7
width: 64 bits
*-logicalcpu:7
physical id: 0.8
width: 64 bits
*-logicalcpu:8
physical id: 0.9
width: 64 bits
*-logicalcpu:9
physical id: 0.a
width: 64 bits
*-logicalcpu:10
physical id: 0.b
width: 64 bits
*-logicalcpu:11
physical id: 0.c
width: 64 bits
*-logicalcpu:12
physical id: 0.d
width: 64 bits
*-logicalcpu:13
physical id: 0.e
width: 64 bits
*-logicalcpu:14
physical id: 0.f
width: 64 bits
*-logicalcpu:15
physical id: 0.10
width: 64 bits
*-firmware
description: BIOS
physical id: 4942
version: 542
physical id: 1
physical id: 2
*-pci
physical id: 100
version: 01
width: 32 bits
clock: 33MHz
*-generic:0
physical id: 1
version: 01
width: 32 bits
clock: 33MHz
*-generic:1
physical id: 1.2
version: 01
width: 32 bits
clock: 33MHz
*-generic:2
JWigg
Thanks xbolshe!
Is it right that the Edison uses an internal PCI express bus for communication with peripherials (in DMA mode) like the High Speed UART ?
asss
Sure, it uses a PCI bus for HSU:
root@edison:~# lspci -kvv -d 8086:1192
00:05.0 Serial controller: Intel Corporation Device 1192 (rev 01) (prog-if 02 [16550])
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Interrupt: pin A routed to IRQ 31
Region 0: Memory at ff010400 (32-bit, non-prefetchable) [size=1K]
Capabilities: [b0] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME+
Capabilities: [b8] Vendor Specific Information: Len=08 <?>
Capabilities: [c0] PCI-X non-bridge device
Command: DPERE- ERO+ RBC=512 OST=1
Status: Dev=ff:1f.7 64bit- 133MHz+ SCD- USC- DC=simple DMMRBC=512 DMOST=1 DMCRS=8 RSCEM- 266MHz+ 533MHz-
Capabilities: [100 v1] Vendor Specific Information: ID=0000 Rev=0 Len=024 <?>
Kernel driver in use: HSU DMA
root@edison:~# lspci -kvv -d 8086:1191
00:04.0 Serial controller: Intel Corporation Device 1191 (rev 01) (prog-if 02 [16550])
Region 0: Memory at ff010000 (32-bit, non-prefetchable) [size=128]
Kernel driver in use: HSU serial
00:04.1 Serial controller: Intel Corporation Device 1191 (rev 01) (prog-if 02 [16550])
Interrupt: pin A routed to IRQ 28
Region 0: Memory at ff010080 (32-bit, non-prefetchable) [size=128]
00:04.2 Serial controller: Intel Corporation Device 1191 (rev 01) (prog-if 02 [16550])
Interrupt: pin B routed to IRQ 29
Region 0: Memory at ff010100 (32-bit, non-prefetchable) [size=128]
00:04.3 Serial controller: Intel Corporation Device 1191 (rev 01) (prog-if 02 [16550])
Interrupt: pin C routed to IRQ 54
Region 0: Memory at ff010180 (32-bit, non-prefetchable) [size=128]
BR,
xbolshe
