Intel® Makers
9868 Discussions
DRAM initialization of Galileo Gen2: ROM code or firmware?
AInte
Dear community,
I was exploring the DRAM module that is implemented in the Galileo. I want to test the data retention characteristics of the DRAM but I exhibited that if one turns the board on, something writes values to the DRAM. I wanted to disable this procedure but wasn't successful yet. Thus, I was asking myself if there is some initalization code as part of potential ROM code that can not be disabled anyway? Or doesn't the Galileo platform implement any ROM code and everything is initialized within the firmware?
Best,
André
FTinetti
Honored Contributor I
Hi André,
I've seen that if Galileo is turned on without SD, the firmware boots yocto (Linux) in RAM, so maybe the DRAM is initialized/written at boot time. I think something similar may happen when booted with SD, but I've not checked. I don't know about how yocto handles the different types of Galileo RAM.
HTH,
Fernando.
Community Manager
Hi an.schall,
That's an interesting question. Let me investigate about it to see if I'm able to get a better answer for you. I'll post an update as soon as possible.
Diego
asss
Valued Contributor II
a DDR3 memory initialization is performed by a code of SPI flash memory.
So, it is possible to compile own SPI flash memory image with disabled DDR3 initialization or DRAM memory access.
BR,
xbolshe
AInte
Dear all,
I guess the central initialization is done in /QuarkSocPkg/QuarkNorthCluster/MemoryInit/Pei/meminit.c. I am trying to locate whether there is code (i.e. the POST functions that writes values to the DRAM. However, given a brief scan I couldn't find any code that does so. Alternatively, given that the Galileo has DDR3 memory, there might be a DDR-related init sequence that initalizes the memory (i.e. precharges it) that might introduce values to the DRAM.
I will try to setup Olimex HW debugger to debug the source in order to get a clearer picture.
Best
Community Manager
Hi an.schall,
I'm sorry for the delay. I see that you have posted an update. Regarding your first question, the firmware initializes the DRAM and it is open source. There is no ROM code on the Galileo platform.
Could you let us know if you are booting from the on-board flash?
Diego
AInte
Dear Diego,
I am booting from SPI flash. I guess it is because of some training phase/ init phase xbolshe was pointing at.
Best,
André
asss
In my understanding, there is an init sequence:
static const MemInit_t init[] =
{ 0x0101, bmCold|bmFast|bmWarm|bmS3, clear_self_refresh }, //0
{ 0x0200, bmCold|bmFast|bmWarm|bmS3, prog_ddr_timing_control }, //1 initialise the MCU
{ 0x0103, bmCold|bmFast , prog_decode_before_jedec }, //2
{ 0x0104, bmCold|bmFast , perform_ddr_reset }, //3
{ 0x0300, bmCold|bmFast |bmS3, ddrphy_init }, //4 initialise the DDRPHY
{ 0x0400, bmCold|bmFast , perform_jedec_init }, //5 perform JEDEC initialisation of DRAMs
{ 0x0105, bmCold|bmFast , set_ddr_init_complete }, //6
{ 0x0106, bmFast|bmWarm|bmS3, restore_timings }, //7
{ 0x0106, bmCold , default_timings }, //8
{ 0x0500, bmCold , rcvn_cal }, //9 perform RCVN_CAL algorithm
{ 0x0600, bmCold , wr_level }, //10 perform WR_LEVEL algorithm
{ 0x0120, bmCold , prog_page_ctrl }, //11
{ 0x0700, bmCold , rd_train }, //12 perform RD_TRAIN algorithm
{ 0x0800, bmCold , wr_train }, //13 perform WR_TRAIN algorithm
{ 0x010B, bmCold , store_timings }, //14
{ 0x010C, bmCold|bmFast|bmWarm|bmS3, enable_scrambling }, //15
{ 0x010D, bmCold|bmFast|bmWarm|bmS3, prog_ddr_control }, //16
{ 0x010E, bmCold|bmFast|bmWarm|bmS3, prog_dra_drb }, //17
{ 0x010F, bmWarm|bmS3, perform_wake }, //18
{ 0x0110, bmCold|bmFast|bmWarm|bmS3, change_refresh_period }, //19
{ 0x0111, bmCold|bmFast|bmWarm|bmS3, set_auto_refresh }, //20
{ 0x0112, bmCold|bmFast|bmWarm|bmS3, ecc_enable }, //21
{ 0x0113, bmCold|bmFast , memory_test }, //22
{ 0x0114, bmCold|bmFast|bmWarm|bmS3, lock_registers } //23 set init done
And need to modify it to fix your problem.
BR,
xbolshe
asss
21.10 Memory Training Engine Lockdown
As part of DDR3 memory initialization code, the Intel® Quark™ SoC UEFI firmware
makes use of a hardware engine to assist in the training of memory. Once DDR3
memory initialization is complete, Intel® Quark™ SoC UEFI firmware locks the
hardware training engine to prevent further training sequences being initiated.
File Path: QuarkSocPkg\QuarkNorthCluster\MemoryInit\Pei\meminit.c
Function: lock_registers
Source: http://www.intel.com/content/dam/www/public/us/en/documents/guides/quark-x1000-uefi-firmware-writers... http://www.intel.com/content/dam/www/public/us/en/documents/guides/quark-x1000-uefi-firmware-writers...
BR,
xbolshe
AInte
Indeed, this is the table I also stumpled over. I can see that I see remenance effect if I do a warm restart but not with cold reboot. Thus I will try to modify the code to enforce warm flow in any case.
asss
Or may be need just halt a processor with an infinite loop during this procedure:
__asm {
label_halt:
hlt
jmp label_halt
BR,
xbolshe
AInte
Thanks, this is another alternative. However, I will first have to see at which point I can insert this code such that DRAM is initialized minimalistically but not overwritten.
AInte
An update regarding my investigations:
In order to read from the DRAM the following registers must be programmed such that commands can be issued to DDR memory:
Dco.field.PMICTL = 0; Dco.field.IC = 1;
Copying these instruction (including the preceeding ones taken from set_ddr_init_complete()) to different locations of meminit.c in order to find the earliest code location that allows for reading the DRAM leads to the following observations:
1. DRAM can be read as early as at the end of ddrphy_init() but it again shows pre-initialized values. I am currently figuring out if it can be read a bit earlier.
2. Warm resets will always allow to read the previously stored values it the warm flow doesn't call certain functions. However, calling the function "dram_init_command(emrs1Command.raw)" that is part of jedec_init, which would NOT BE CALLED during a warm reset, pre-initializes the values.
Maybe as part of the physical level initalization some precharging is performed that would lead to preinitialized values.
Community Manager
Hi an.schall,
I'd like to know how your investigations are going. Do you have additional updates or questions?
Diego
AInte
Dear Diego,
I am still no able to identify the part of the code that pre-initializes the DRAM memory values. I figured the earliest point in time to read out the memory (ddrphy_init before step 4a). However, reading the contents of the DRAM at this time reveals a very structured pattern that seems identical for almost all banks of the DRAM but it is different among multiple Galileo devices. I know that part of the JEDEC DDR3 standard, the cells will be precharged and there are also some read and write leveling sequences. However, as far as I can tell all the precharging and leveling is done in perform_jedec_init as well as wr_level, rd_train, wr_train. Thus, I guess the structure that I can observe must be due to some other code. Potentially, at a very early stage all the wordlines are actived and since the capacitors hold Vdd/2 the amplifiers (more or less) randomly decide whether there is a 0 or 1. So currently, I am still trying to find the code that is in charge of pre-initializing the DRAM cells.
Best
Community Manager
I see… I'll try to find any additional information that could be useful for you.
Additionally, I'm confused about the file you attached, can you explain it?
Diego
AInte
Regarding the attached file: It is a false-color map (heatmap) of a 32 KB section of the DRAM. I took 5 measurements (unplugging the board in between) and created for each cell the probability of having a "1" bit. Thus, yellow cells show cells that have a "1" bit in all of the five measurements while dark blue ones refer to those with 0 value. Basically, it is a bitmap of the startup pattern of a 32 KB DDR3 segment averaged over 5 measurements.
Community Manager
Hi an.schall,
Thanks for the explanation.
I'll try to find additional information that helps you on this.
Diego
AInte
Dear Diego,
do you have any updates regarding the remenance effect?
Best,
André
Community Manager
Hi an.schall,
I apologize for the delay in my response, but unfortunately I don't have updates about this yet. We're still investigating about it.
I'll post any update I get as soon as possible. Sorry for the inconveniences.
Diego
Community Manager
Hi an.schall,
Sorry for the delay in my response.
The initialization code is located in the file MrcWrapper.c, in function MemoryInit. In order to skip initializing the memory, you have to remove the following part:
PEI_QNC_MEMORY_INIT_PPI *QNCMemoryInitPpi;
// Configure MRC input parameters.
Status = MrcConfigureFromMcFuses (&MrcData);
ASSERT_EFI_ERROR (Status);
// Locate Memory Reference Code PPI
Status = PeiServicesLocatePpi (
&gQNCMemoryInitPpiGuid, // GUID
0, // INSTANCE
NULL, // EFI_PEI_PPI_DESCRIPTOR
(VOID **)&QNCMemoryInitPpi // PPI
// Call Memory Reference Code's Routines
QNCMemoryInitPpi->MrcStart (&MrcData);
And then, add the following to tell the system how much memory it has (even though the initialization has been skipped):
// Note emulation platform has to read actual memory size
// MrcData.mem_size from PcdGet32 (PcdMemorySize);
MrcData.mem_size = PcdGet32 (PcdMemorySize);
Hope it helps you.
Diego
