Intel® Makers
9881 Discussions
Data is not being sent to ThingSpeak via Edison
Swati_S_Intel
My ping command to ThingSpeak is not responding when I am trying to connect my edison to ThingSpeak. I am using Arduino IDE.
I need to update once to ThingSpeak. Is there any mistake in code?
Please let me know.
# include
# include
# include
//Ultrasonic Sensor
# define echoPin 11
# define trigPin 12
# define indicatorLedPin 13
// Configuring Wifi
char ssid[] = "WirelessNetworkName"; // wireless network name
char password[] = "WirelessNetworkPassword"; // wireless password
int status = WL_IDLE_STATUS;
WiFiClient client;
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String APIKey = "4XZ9NA14HQZ7BYD7"; // enter your channel's Write API Key
const int updateThingSpeakInterval = 20 * 1000; // 20 second interval at which to update ThingSpeak
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
int calibrationTime = 10000;
static int count = 1;
void setup() {
// Start Serial for debugging on the Serial Monitor
Serial.begin(115200);
pinsInit();
connectWifi();
printWifiStatus();
Serial.println("Starting cloud implementation of computation of traffic density...");
turnOnLED(); // turn on the indicator LED to indicate that calibration is happening
calibrate();
turnOffLED(); // turn off the indicator LED to indicate that calibration is completed
delay(50);
vehicleDensity();
// This function //
void pinsInit()
pinMode(echoPin, INPUT);
pinMode(trigPin, OUTPUT);
pinMode(indicatorLedPin, OUTPUT);
void connectWifi() {
// Attempt to connect to wifi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid);
// Wait 10 seconds for connection
delay(10000);
void printWifiStatus() {
// Print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// Print your WiFi IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// Print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void turnOnLED()
digitalWrite(indicatorLedPin,HIGH);
void turnOffLED()
digitalWrite(indicatorLedPin,LOW);
void calibrate ()
Serial.println("Ultrasonic sensor");
// add a calibration setup
// calibrate during the first ten seconds
Serial.println("Please calibrate your ultrasonic sensor in the next 10 seconds");
digitalWrite(indicatorLedPin, HIGH); // turn on the indicator LED to indicate that calibration is happening
for (int i = 0; i < calibrationTime; i++) {
Serial.print(".");
delay(100);
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
void vehicleDensity()
long duration, distance;
int offset = 1;
//Ultrasonic Sensor
for (int i = 10; i > -1; i--) {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) / 29.1;
Serial.print("Count: ");
Serial.println(count);
Serial.print("Distance: ");
Serial.print(distance);
Serial.println(" cm");
count++;
Serial.print("No of vehicles:");
delay(1000);
Serial.println("");
String countVal = String(count,DEC);
// Disconnect from ThingSpeak
if (!client.connected() && lastConnected) {
Serial.println("...disconnected");
Serial.println();
client.stop();
// Update ThingSpeak
if (!client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval)) {
updateThingSpeak("field1=" + countVal);
Serial.println(countVal);
lastConnected = client.connected();
// Print Update Response to Serial Monitor
rcv_ans();
void updateThingSpeak(String tsData) {
if (client.connect(thingSpeakAddress, 80)) {
Serial.println("connecting...");
// POST URI
client.print("POST /update HTTP/1.1\n");
Serial.println("POST /update HTTP/1.1\n");
// Host header
client.print("Host: api.thingspeak.com\n");
Serial.println("Host: api.thingspeak.com\n");
client.print("Connection: close\n"); ////////////////////////////////////////////////////////////
// ThingSpeak Services application key
client.print("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
Serial.println("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(tsData.length());
client.print("\n\n");
client.print(tsData);
lastConnectionTime = millis();
while (client.connected()) {
Serial.println("Connecting to ThingSpeak...");
Serial.println();
else {
// If you couldn't make a connection:
Serial.println("Connection failed");
Serial.println("Disconnecting.");
client.stop();
void rcv_ans(){
while (client.available()) {
char c = client.read();
Serial.print(c);
Community Manager
Hi SwatiD,
The first thing when configuring a Thingspeak is creating a channel. Once the channel is created you'll have the option to add data by sending a POST or GET to a provided URL. Make sure you've put the correct URL into your code. You can see a descriptive video on how to add data in Thingspeak here http://www.instructables.com/id/INTEL-EDISONWIFITHINGSPEAK/?ALLSTEPS http://www.instructables.com/id/INTEL-EDISONWIFITHINGSPEAK/?ALLSTEPS .
Now, when doing the Arduino code, it's important to set the correct variables with the Thingspeak settings, such as the address and the writeAPIKey. One thing I noticed from your code is you don't have a loop () in your code. I'd suggest you to take a look at https://software.intel.com/en-us/articles/internet-of-things-a-plant-monitor-on-the-intel-edison-boa... https://software.intel.com/en-us/articles/internet-of-things-a-plant-monitor-on-the-intel-edison-boa... . This link has an example on how to use Thingspeak with Arduino and has the sample code divided into the different sections needed to build the custom code. It has sections such as declaring the variables, read from the feed, what information should be on the setup () and loop () sections of the code, and how to interact with different sensors.
I'd suggest you to take a look at the previous link and have it as a reference on what sections should be on your code and what functions are used to communicate with Thingspeak.
Let us know if you find this useful.
-Sergio
Swati_S_Intel
HI Sergio,
Thank-you for replying. I got my code working with few amendments.
I have intentionally put blank loop () since I don't need to record response time of ALERT as part of my project.
Thank-you for the help
Community Manager
Thank you for letting us know you managed to get the code working. If you have other questions don't hesitate to open a new thread to receive help from the community.
-Sergio
