Intel® Makers
9873 Discussions
Datalogging from Arduino sketch into internal storage
AGil
Hello everyone,
I'm working with some Arduino compatible sensors, an Arduino sketch and the Intel Edison.
I have been able to save data from those sensors into an external microSD without problems, but i'm trying to save the data into the internal storage of the Intel Edison. I want to do that because in a future, i would like to use this stored data in another Linux application using the same Intel Edison.
The thing is that i don't exactly know if this would be possible or not and, in case it wouldn't, what could i do instead?
All kind of help would be very useful.
Thank you all!
Diego_V_Intel
Hello mr_calin,
I believe you are using the SD library to store the files in the SD card, right? Then, to store the files in the Edison's internal storage you have to do one little modification in the SD library. Follow the steps below:
1. Open the SD.cpp file. It is located in the following directory: C:\...\[arduinoIDE]\hardware\intel\i686\libraries\SD\src\SD.cpp
2. Modify the line 37. It looks like this:
const char* SD_MOUNT_PATH = "/media/sdcard";
3. Modify the path. For example, you can use the home directory to store the files so the new line should look like this:
const char* SD_MOUNT_PATH = "/home";
4. Save the file
Then, if you upload your Arduino sketch again, the files should be stored in the /home directory.
Diego.
Diego_V_Intel
Hello mr_calin,
4. Save the file
Diego.
AGil
Hi Diego,
Thank you so much for your help! Really apreciate it! It was no trivial because i have found so many different SD.cpp files with the same name, and because i was thinking on finding the datalogging file in the masive 800 Mb storage of the Edison, but i'm reading in the forum that that's only the update partition. It is inside the home folder, in the main partition and accessible by a putty terminal. Just what i was looking for.
Really grateful for your help.
Andrés.
