Intel® Makers
Debugging C#
АКрыц
Hi.
I installed mono on the Intel Edison. Compiled and assembled the application. Everything works. Now I need to learn how to debug.
Q: Anyone have experience using debugging a C# application from visual Studio in Edison? What Visual Studio plugin can be used for remote debugging?
Pablo_M_Intel
Hi akrizkiy,
Visual Micro is a free plugin for MS Visual Studio that supports Arduino 3rd party build processes. However, according to a post from March it's no longer compatible with Arduino. Still I would suggest you to try with this plugin and see if it no longer works, check this link .
About debugging an application from Visual Studio, we have no experience with this. Maybe you can find some useful information from here http://visualgdb.com/tutorials/linux/edison/ http://visualgdb.com/tutorials/linux/edison/. I would also suggest you to contact the Visual Studio support team, https://www.visualstudio.com/en-us/support/support-overview-vs.aspx https://www.visualstudio.com/en-us/support/support-overview-vs.aspx.
PabloM_Intel
АКрыц
Thank's.
1. Visual GDB - cool pulgin, but for C++ developing. Maybe it supports C# . Requested technical support
2. Visual Micro - Arduino way.
3. Visual Studio support team - Ask them on the forum
Also found another solution http://www.monodebugger.net/ MonoDebugger.NET - Debug your Mono applications with Microsoft Visual Studio
The project looks not alive, but maybe can be modified. The source code is on github.
If I find a solution, I'll write in this thread
АКрыц
P.S. Answer from support Visual GDB: "Visual GDB not supported C# "
