Community
cancel
Showing results for
Search instead for
Did you mean:
BHash2
Debugging an OS X Setup
Hi there,
I'm having intermittent problems and would appreciate any tips. My setup is a MacBook Pro with OS X Yosemite (10.10.5)
Problems I'm facing include:
- Only occasional mounting of the Edison Drive (not sure what triggers the mounting)
- Failure on trying to copy files onto the Edison Drive (either via Finder or using command line)
- In particular, I get the following:
cp -v ~/Desktop/Edison/edison-image-ww25.5-15/edison-image-edison.ext4 /Volumes/Edison
cp: /Volumes/Edison/edison-image-edison.ext4: Input/output error
cp: /Volumes/Edison/edison-image-edison.ext4: fchmod failed: Bad file descriptor
cp: ~/Desktop/Edison/edison-image-ww25.5-15/edison-image-edison.ext4: could not copy extended attributes to /Volumes/Edison/edison-image-edison.ext4: No such file or directory
Goodness: I can consistently "screen" into the Edison via the USB-to-serial connection
Unfortunately, this occasional availability of the Edison drive is preventing me from flashing the firmware -- tried the Phone Tool, flashall and "reboot ota" techniques and all don't work for me.
Other diagnostics:
$ ls /dev/*usb*
/dev/cu.usbserial-A502P40I /dev/tty.usbserial-A502P40I
$ ls /Volumes/Edison
ls: /Volumes/Edison: No such file or directory
$ dfu-util -l
{Shows nothing listed}
$ sudo ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
{No response even after I remove plugs and re-seat both USB Cables}
Any ideas?
Pablo_M_Intel
Hi bhashem,
Did you already discard a problem with the USB cables or ports that you're using? Some other user already reported this behavior and he was able to solve it by changing the USB ports.
PabloM_Intel
BHash2
Thank you Pablo, ensuring that I use the SAME cables every time in the same EXACT USB slots seems to solve my problem for getting the Edison disk to consistently mount.
Unfortunately, I still can't flash either with the reboot ota method or the flashall.sh method as the board is not being recognized.
Thank you for any ideas and help.
Pablo_M_Intel
Hi bhashem,
Have you already tried flashing your board with Flash Tool Lite? To download the tool I would suggest you to follow this link https://software.intel.com/en-us/articles/flash-tool-lite-user-manual https://software.intel.com/en-us/articles/flash-tool-lite-user-manual, you'll also find instructions on how to install it.
In the link below you can find instructions on how to complete the flashing process using the tool.
https://software.intel.com/en-us/flashing-firmware-with-flash-tool-lite IoT - Flashing your firmware with Flash Tool Lite | Intel® Developer Zone.
PabloM_Intel
Carlos_M_Intel
Hi bhashem,
Did you try by re-flashing the board?
Do you have updates on this?
Charlie
BHash2
Hi there,
I finally got it to work -- YES! I noticed that the disk format was still FAT16. I re-partitioned the Edison drive to FAT32, copied the files over and was able to successfully do a "reboot ota". I was able to verify that the new version was installed by examining /etc/version.
Thank you for your help and suggestions.
-Basil
